Code Exchange
Code Exchange
Forum how to read mic in esp32 s3 sense using micropython
Join Code Exchange to participate - click to join for free!
  • Subscribers 48 subscribers
  • Views 2881 views
  • python
  • micropython
manojroy123
manojroy123 over 2 years ago
Does anyone knows how to read microphone in esp32 s3 sense development board using micropython.
    0 dougw over 2 years ago
    You could check ESP BOX at Adafruit to see if it is compatible.
  • manojroy123
    0 manojroy123 over 2 years ago in reply to dougw
    There are micropython code that are available but it is showing pin error in it.
    Please check the bellow code
    import machine
    import time
    import ustruct
    # Configure I2S for the built-in microphone
    # Pin definitions for ESP32-S3 (based on ESP32-S3 Sense specs)
    # These may vary depending on the board revision. Check the datasheet.
    I2S_SCK = 18 # Serial clock pin
    I2S_WS = 19 # Word select (left/right channel)
    I2S_SD = 21 # Serial data input pin (microphone data)
    # Set up I2S
    i2s = machine.I2S(
    id=0, # I2S interface 0
    sck=machine.Pin(I2S_SCK), # Serial clock pin
    ws=machine.Pin(I2S_WS), # Word select pin
    sd=machine.Pin(I2S_SD), # Serial data input pin
    mode=machine.I2S.MASTER, # Mode is master
    bits=16, # Data bits per word (16-bit audio)
    format=machine.I2S.MONO, # Mono audio (single channel)
    rate=16000, # Sampling rate in Hz (typically 16kHz for mic)
    dma=True # Use DMA (Direct Memory Access) for efficient data transfer
    # Buffer to store audio data (e.g., 256 bytes for each read)
    buffer = bytearray(256)
    while True:
    # Read audio data from the microphone
    bytes_read = i2s.readinto(buffer)
    if bytes_read:
    # Process the data (e.g., printing first 10 bytes for debugging)
    print("Data read from mic:", [ustruct.unpack('<h', buffer[i:i+2])[0] for i in range(0, bytes_read, 2)])
    # Delay to allow for continuous reading at a reasonable rate
    time.sleep(0.1)
  • manojroy123
    please check this link as well.
    https://wiki.seeedstudio.com/xiao_esp32s3_getting_started/
    GPIO 41, GPIO 42 is for mic configuration but missing word select pin for mic
  • bidrohini
    0 bidrohini over 2 years ago in reply to manojroy123
    The ESP32-S3 Sense has a built-in PDM microphone. For I2S, verify that the pins you've defined (I2S_SCK, I2S_WS, and I2S_SD) match the board's actual pinout. Not all pins on the ESP32-S3 support I2S. Verify that your selected pins are valid I2S pins by consulting the ESP32-S3 datasheet or technical reference manual. You may also want to check this Raspberry pi passed voice control project for some references: www.theengineeringprojects.com/.../voice-control-project-using-raspberry-pi-4.html
