Code Exchange
Code Exchange
Forum code
Join Code Exchange to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 52 subscribers
  • Views 1833 views
  • frontpage
code
i need  adriuno sample code that include dc moter, sensor,bluthoth modulatar,push buten
    shabaz over 10 years ago in reply to e14 Contributor +3
    No, it isn't plug-and-play level of ease of use. Think of it like building a house. You're trying to build a house without knowing how to build a wall first and without knowing how to mix cement. There…
  • gadget.iom
    gadget.iom over 10 years ago +1
    Great! What have you got so far?
    balearicdynamics over 10 years ago +1
    Maybe there is some confusion between code exchange (including experiences, tips, tricks etc.) and request the sources you need and we'll send you ? Enrico
  • gadget.iom
    Great! image
    image Enrico
  • neilk
    neilk over 10 years ago
    You probably need to post some specific questions in the Arduino group.
    i have one dc moter and bluthooth modulater and ultasonic sensor and 2 push button and also LED. the idia is controling the moving car, that is when the push button  touchs the car move forward,backward also when the sensor senses nerar object the car stops. i have separet code for each matrials i trayed but i can't combilete togather.
    ohh i have another qustion i don't have blutooth modularer on my hand. can i replace it with other divce like infrarad (remote control) ?
    There is no short-cut, you need to know how to build the wall first and how to mix cement.
    So, you can forget the possibility of joining all your parts together and getting them to work, it just won't happen until you've learnt the smaller things first.
    To do that, you need to follow some Arduino tutorials perhaps. It might take a few weeks or longer, depending on how fast you learn. To be honest, expect it to take some (many) months if you're a complete beginner.
    Start with blinking an LED and slowly build up..
    Once you've learnt all that, only then can you start designing your own combinations and have enough knowledge to get them working together.
  • beacon_dave
    beacon_dave over 10 years ago in reply to e14 Contributor
    Perhaps start by taking a look at these Arduino tutorials:
    Jeremy Blum Arduino Tutorials
    to learn how to work with basic sensors and actuators.
    Then take a look at some of these rover robot projects:
    Arduino Rover
    ROVER Bot - The Arduino Bluetooth Controlled Tank
    Arduino HC-SR04 Ultrasonic Rover
    or alternatively start with a rover robot kit which has step-by-step instructions:
    Beginner Robotic Kits Arduino Compatible | Into Robotics
    then apply what you have learnt to your own project.
