Code Exchange
Code Exchange
Documents Scratch project for PiFace demo
Join Code Exchange to participate - click to join for free!
  • Author Author: fustini
  • Date Created: 21 Mar 2013 12:37 AM Date Created
  • Last Updated Last Updated: 24 Jun 2013 4:59 PM
  • Views 2676 views
  • Comments 9 comments
Scratch project file created based on the Scratch demo shown in the PiFace documentation:
"Controlling Pi Face with Scratch"
https://docs.google.com/folder/d/0B-UAZ9CyJCLGQjJ3RDlqa2pqaDg/edit?docId=1M0jz7-vaR8mwM4Gc4dBJyh4EheXHd0BCkpBWOEqMOUY
See below under Attachments the file piface1.sb.zip .  Download the file and unzip it.  Scratch should be able to open piface1.sb.  Note: you will first need to follow the instructions in the "Controlling Pi Face with Scratch" link above to get Scratch setup correctly.  (This involves starting a Mesh session and then running the PiFace handler script to connect to the Mesh session.  This allows Scratch to interact with the PiFace.)
For Amazing BrainTeaser contest entries - please post the answer here to enter giveaway: http://www.element14.com/community/docs/DOC-54752
piface1.sb.zip
  • scratch
  • code_exchange
  • piface_digital
  • education
  • pi
  • Code Exchange
  • raspberry_pi
  • rpi
  • codeexchange
  • piface
  • piface
    piface over 12 years ago in reply to fustini +1
    If you're still looking for instructions for using Scratch with Piface, instructions are in this guide. http://www.piface.org.uk/guides/scratch_with_pifacedigital/Setting_up_Scratch/
    This is exactly what I would like to accomplish with Scratch.  Being quite new with graphical programming however is a limitation.  I have Scratch set up and am able to host / mesh etc.  But... I am unsure how to get the' "drop downs for variables to work as they do in the variable blocks themselves.  i.e. how do I get  "piface-input1" Sensor Valule = numberI ..( I only have the usual Scratch inputs to choose from.  I Have the piface1.sb file loaded and running, and works with your program.  This assures me that I am missing the requisite scratch understanding to continue.  Any recommendations as to where to get help??
    Dave
  • fustini
    fustini over 12 years ago in reply to e14 Contributor
    Hi - it's been awhile since I've interacted with Scratch and PiFace. The Raspberry Pi space here on element14 Community is a good place to ask questions. piface is the creator of PiFace I believe.  Their github https://github.com/piface lists pi@cs.man.ac.uk and also http://pi.cs.man.ac.uk/
  • fustini
  • piface
