Connector Technology & Design
Forum Need a Tyco RJ-45 Panel Mount Connector
  • Replies 15 replies
  • Subscribers 131 subscribers
  • Views 3094 views
  • connectors
  • connector
  • ethernet
  • rj45
Catwell over 15 years ago
I need the following Tyco RJ-45 Panel Mount Circular ConnectorTyco RJ-45 Panel Mount Circular Connector, but with a screw down terminal block instead of a 12" attached cable.
I have bought them before, but I can no longer find them anywhere.
Cabe
    e14 Contributor over 15 years ago in reply to jason721
    For the widest range of RJ45 Panel Connectors try the Weidmuller, FrontCom Micro products and/or their IE Line - Classic range
    Further information is available here http://katalog.weidmueller.de/catalog/Start.do?localeId=en&ObjectID=group19580346981564
    or email technical@weidmuller.co.uk
    Stuart
  • Catwell
    Catwell over 15 years ago in reply to jason721
    Jason,
    Unfortunately, I have sent them all out with products I built.
    Terminal blocks are a definite plus, but I am just looking for the best prices. So far, Newark/Element 14 store has the cheapest plugs.
    Cabe
  • jason721
    jason721 over 15 years ago in reply to Catwell
    Are you going to be using the mating connector or just using this as way to get through the panne?
    So what would you next choice of terminaiton be that you would want?
  • Catwell
    Jason,
    You are quick to respond!
    For the next termination option I would go with at least a 6" (inch) lead off the back. I know that exists, I buy them all the time. I just don't know which Tyco part number it is in the Element 14 store.
    Cabe
  • jason721
    Tyco as you pointed out earlier has the one with 12" leads. However they come with 3 different wiring options (10 Base-T, 568A & 568B). This has to do with the wiring lay out in the connector. The below link will show these layouts.
    http://www.accesscomms.com.au/reference/lanwiringschemes.htm
    Food for thought though: The only one in stock is under Part# 20M8019 (the one you had earlier) this is the 10 Base-T but the others can be ordered.
    568A - 20R9776
    568B - 08P5233
    Check out page 26 of the data sheet.
    Tyco Data Sheet
