Connector Technology & Design
Forum Need a Tyco RJ-45 Panel Mount Connector
  • Replies 15 replies
  • Subscribers 131 subscribers
  • Views 3103 views
  • connectors
  • connector
  • ethernet
  • rj45
Catwell over 15 years ago
I need the following Tyco RJ-45 Panel Mount Circular ConnectorTyco RJ-45 Panel Mount Circular Connector, but with a screw down terminal block instead of a 12" attached cable.
I have bought them before, but I can no longer find them anywhere.
Cabe
  • jason721
    jason721 over 15 years ago
    This part is actually to a PCB that you would need to solder wire to.
    For the original part though are you sure its a Tyco?
  • Catwell
    Catwell over 15 years ago in reply to jason721
    Right, This is the Tyco part with the 12" cordTyco part with the 12" cord.
    Yes, it looks the exact same, but has a breakout screw down terminal block.
    Cabe
  • MolexConnectors
    MolexConnectors over 15 years ago in reply to Catwell
    Hi Cabe,  See if you can find a part that will work for you on the Molex website. Check out our Circular Industrial Connectors overview page. Once you find the part you want, you can probably order it from Newark/Farnell.  Let me know if you have any questions.
  • Catwell
    Catwell over 15 years ago in reply to MolexConnectors
    Molex,
    I looked through your catalogue, and I can not find the rj45 (Ethernet) receptacles. Can you help me with that?
    Cabe
  • MolexConnectors
    Hi Cabe,
    See if this link will help you.  I atatched a screen shot showing you the parts that look similar to what you are looking for. Let me know if you have any more questions.
  • Catwell
    Yes, one more question. Can you help me find all of those at Newark or the Element14 store?
    Cabe
  • MolexConnectors
    Perhaps one of the Newark or E-14 members on the site can help you locate a part if you list which part you are looking for.  You can also go back to the link I provided to you.  Click on a part number you want.  We offer an option to see right away which distributors have the part in stock. Just click on "Check Distributor Inventory" I have a screen shot attached for you. Please let me know if you need additional help with this.  Thanks.
  • firatkocak
    firatkocak over 15 years ago in reply to Catwell
    Hi Cabe,
    www.findchips.com is a very well source to locate a part in many reseller like Digi-Key,Newark,Farnell etc.
    Firat
  • jason721
    jason721 over 15 years ago in reply to MolexConnectors
    Looking through the parts Molex offeres I did not see any that have a  terminal block termination. The unique parts that I saw was a punch down  would be like a typical RJ-45  terminaion (IDC) and cable assembly that would be from connector to connector.
    I talked with Tyco Tech Support and  they couldn't find any that had for a terminal block. Also browsed  thorugh Amphenol's and they had the same terminations as Tyco.
    Feed through (Jack to Jack)
    PCB termiation
    WIre Termiation
  • jason721
    jason721 over 15 years ago in reply to firatkocak
    Cabe,
    You don't happen to have one of your original connectors laying around do you?
