Connector Technology & Design
Forum How to implement USB 3.0 with Altera Cyclone III FPGA ?
  • Replies 7 replies
  • Subscribers 129 subscribers
  • Views 2282 views
apatro
apatro over 16 years ago
I am planning to implement USB 3.0 interface for Altera Cyclone III FPGA board. The need for USB 3.0 came from more speed requirements. SuperSpeed USB 3.0 supports a maximum data rate of 4.8 gigabits per  second offering 10x performance increase over Hi-Speed USB (USB  2.0).
Comparison  of USB 3.0 to USB 2.0
Features
USB 3.0
USB  2.0
Speed
Upto 4.8 Gb/s
upto 480 Mb/s
Signaling
Dual-simplex four wire differential   signaling
Two wire differential signaling
Data  flow
Full duplex
Half  duplex
Power Management
Multi-level which supports idle, sleep, and   suspend
Port-level that has two levels of   entry/exit latency
Cable  types
Shielded  differential   pair (SDP)
Unshielded twisted pair  (UTP)
Cable Wires
8 total
4 total
Traffic  Flow
Asynchronous
Polled
Packet  Traffic
Explicitly routed
Broadcast to all devices
What functional block and peripheral devices should be required in the Cyclone FPGA board design to implement SuperSpeed USB 3.0 interface ?Any suggestions/comments will be much appreciated.
  • apatro
    0 apatro over 16 years ago
    can I use USB 3.0 controller  µPD720200 chip from NEC for my soulution ? any comments??
  • suresh
    0 suresh over 16 years ago
    Hi Anil,
    When considering the Cyclone III FPGA, what is the most important feature to you?
    like I/O pins,high perfomance, low power, memory, low cost, please specify if any other....
    in this development are you considering Cyclone IV FPGA also?
    regards
    suresh
  • apatro
    0 apatro over 16 years ago in reply to suresh
    The important feature will be high performance and low cost. We are considering now Cyclone III FPGA board with USB3.0 interface.
  • apatro
    How about to use Texas USB1310 PHY IC for USB3.0 interface ? Any suggestion or tips ?
    0 e14 Contributor over 16 years ago in reply to apatro
    Can I have the reference design using USB1310 PHY?
  • apatro
    0 apatro over 16 years ago in reply to e14 Contributor
    you can refer this link where a top level architecture is shown -
    http://www.slscorp.com/pages/ipusb30sls.php
  • ngadhia
    0 ngadhia over 15 years ago in reply to apatro
    Check out the tutorial video at: http://vimeo.com/26366020
