Connector Technology & Design
Forum Looking for a small 8 pin connector - male and female
  • Subscribers 129 subscribers
  • Views 854 views
  • pin
  • connector
  • 8
I am looking for small 8 pin connectors - think the size of micro USB. I will need to run a mix of audio, power and data signals through. I would need both options for attaching on cords as well as on PCBA. Size is important - any ideas guys?
    Dear Tino,
    I saw your message here this morning and noticed that no one had replied. Unforunately, our tech team has never seen a connector like what you describe.  Our closest offering would be an 8-pin Mini-DIN connector, but that is much larger than a micro USB.  If it is of any help, our free engineering drawing download shows the exact dimensions of an 8-pin Mini-DIN connector for reference.
    http://www.l-com.com/ReturnImage.aspx?ImageUrl=~/product_images/detail/CED_MINI-DIN_8-F.JPG&Height=500&Width=500
    I hope someone else can give you a better answer!  I look forward to discovering a connector that meets your needs.
    Dave
  • Catwell
    0 Catwell over 14 years ago
    What type of power? DC?
    The audio and data signal lines will most likely interfere with each other, as well as absorb noise from the power lines.
    If signal integrity is not a concern, anything would work. A 9-pin din plug. Or build your own cable using 8 conductor CPC connectors and shielded cables.
    I do a lot with CNC equipment, where signal integrity is imperative.
    I am always looking for an alternative to what I use. (I need something similar to you.) From my experience, placing all those lines together will cause issues. I had a problem with the 60Hz from AC power, and had to use differential cable drivers to protect the signal. My machines wen from cutting ovals to the proper circles.
    Cabe
    http://twitter.com/Cabe_e14
    Dear Tino,
    We’ve just launched a possible solution for you. Please check out our latest innovation, the CeeLok FAS-T Connector, here: http://www.te.com/en/product-launch/future-unleashed/ceelok-fas-t-connector.html
    Earle
  • LaurenceHillGCT
    0 LaurenceHillGCT over 14 years ago
    Hi Tino,
    Better late then never, I guess your design might be closed by now, however perhaps these Micro USB3.0 pcb connectors might help:  http://www.element14.com/community/docs/DOC-50438/l/news-release-usb30-connectors-super-speed-in-micro-format
    The GCT Micro USB3.0 receptacles have 10 contacts, although tiny are not quite as small as Micro USB2.0 as they have the extra cavity with 5 extra contacts to allow USB3.0 'Superspeed' , they are in the same tiny ballpark.
    GCT don't sell the cable assemblies, but I think you can pick these up off the shelf at Farnell, see 18612641861264 example cable with Micro B USB3.0 plug.  GCT offer both B and A/B PCB receptaces, type B being practically more popular as the A/B type is normally used for on the go applications.
    Regards
    Laurence Hill
    Marketing Manager
    Global Connector Technology
