Connector Technology & Design
Forum Seeking Your Interest in Receiving Solderless Compression Mounted RF Connectors to Experiment With
  • Replies 20 replies
  • Subscribers 126 subscribers
  • Views 5791 views
  • sv microwave
  • rf connectors
  • community poll
  • solderless compression mounted connectors
rscasny
rscasny over 3 years ago
imageI have been in conversation with one of our suppliers who makes solderless compression-mounted RF connectors. They say these connectors are desirable for their fast and easy installation compared to standard soldered connectors. They are rugged and durable, and can be customized for the PCB footprint. While they aren't the solution for every situation, they are used for applications such as RF test and measurement boards; High Speed Digital component test equipment; and stripline, microstrip and coplanar waveguide PCB launch connectors.
Here's some documentation on these connectors:
www.svmicrowave.com/.../Solderless_Compression_Mount_Study.pdf
www.svmicrowave.com/.../LiteTouch_Solderless_PCB_Connectors_Application_Note.pdf
www.svmicrowave.com/.../Solderless_PCB_Compression_Mount_Connectors_Application_Note.pdf
www.svmicrowave.com/solderless-pcb-edge-launch
https://svmicrowave.com/high-speed-solderless-pcb-connectors
What we would like you to do
We would like to send a few members some of these connectors to experiment with informally and write a blog about their thoughts and testing of them. The blog would be something like this one: click here to view.
Here are some of the types of solderless compression mounted RF connectors we would give you:
image image image image
SF2921-61507 RF / Coaxial Connector, PCB SMD, SMA Coaxial, Straight Flanged Jack, Compression, 50 ohm  SF2921-61507 SF1521-60061 RF COAXIAL, 2.92MM JACK, 50 OHM, PANEL  SF1521-60061 SF3321-60040 RF / Coaxial Connector, 1.85mm Coaxial, Edge Launch Jack, Board Edge / End Launch, 50 ohm   SF3321-60040 SF1521-60013 RF / Coaxial Connector, 2.92mm Connector, Straight Jack, 50 ohm, Beryllium Copper  SF1521-60013
**Participants will receive a giveaway prize that needs to be determined.
  • rsjawale24
    rsjawale24 over 3 years ago +4
    The compression mount type SMAs are quite popular in mmWave microwave circuits. I have specialised in antennas and I have been using the normal edge mount SMAs from Wurth or Molex that work upto 18 GHz…
  • rscasny
    rscasny over 3 years ago +3
    Hi all, I wanted to touch with anyone interested in participating in this little project. Since we haven't really done anything (that I can recall) on solderless compression connectors, I'm interested…
    shabaz over 3 years ago +2
    Thanks Jan Cumps I didn't see this. I'll write up a mini-proposal and send it across to see if it is of interest. I can think of several applications where it could be very useful.
  • colporteur
    colporteur over 3 years ago in reply to rscasny
    Thanks RS. That describes the physical mounting of the connector, What about the center pin to PCB, must be a compression fit with flanges.
    shabaz over 3 years ago in reply to colporteur
    It's a pin-on-a-spring, that presses against the PCB trace:
    shabaz over 3 years ago in reply to Jan Cumps
    Same here, I can only really use SMA (i.e. SF2921-61507 ). The other connectors are more specialist. Still, it's no bad thing if several of us use SMA, if the manufacturer is OK with this, since then we can bounce ideas off each other : )
  • rsjawale24
    rsjawale24 over 3 years ago in reply to rsjawale24
    Had to change my vote at the last minute. Unfortunately, I'm busy with two back to back conferences in December. I'm going to present paper on a similar design as above.. reconfigurable antenna...
  • rscasny
    rscasny over 3 years ago in reply to rsjawale24
    That's too bad. But I fully understand. Have a successful conference presentation.
    Randall
    -element14 Team
  • rscasny
    rscasny over 3 years ago in reply to shabaz
    They didn't give me any special requirements on the product to use. So, I'll get the SF2921-61507.
    Thanks.
  • rscasny
    rscasny over 3 years ago in reply to Jan Cumps
    I can get you the same one that Shabaz plans on using.
  • rscasny
    How many connectors would you like?
    Jan Cumps over 3 years ago in reply to rscasny
    Thank you. That would be great. And we may be able to get some posts on the PCB design forums too.
    shabaz over 3 years ago in reply to rscasny
    Hi Randall,
    Thanks for this! They are a bit pricey but four of them would be really helpful. But can manage with 3 if that's not feasible. I don't need any cables, I have enough of those.
