Embedded and Microcontrollers
Blog C++ library for ST Teseo GPS - pt. 9: 2.0 release - stable
  • Date Created: 1 Sep 2024 11:08 AM Date Created
  • Views 510 views
  • raspberry
  • pico
  • nmea
  • c++23
  • Teseo
  • gps
  • teseo_c++
1 Sep 2024
The Teseo-LIV3 GPS module (as used in shabaz ' GPS / Galileo / BeiDou / GLONASS receiver) talks UART and I2C. I developed an OO driver and parser for it.
The Raspberry Pico port of that library is now ready for release 2.0.
GitHub 2.0 release with binaries
Main changes:
  • parser has more coverage for NMEA responses and attributes (everything used in shabaz' Arduino library)
  • faster UART interface
  • uses consistent naming conventions and C++ constructs, compliant with µOS coding standards.
  • STL aggregate and filter examples
  • Teseo and NMEA library now are STL container independent, and support embedded-friendly std::array
Check the release notes via the link above, for a full list of changes
Pico resources used only if you use I2C:
  • I2C0
  • SDA: GP16 (Pico I2C0 SDA)
  • SCL:  GP17 (Pico I2C0 SCL)
  • baud: 100 * 1000
for I2C, SDA connects to SDA and SCL to SCL. The PCB that I use has the pull-ups for I2C.
Pico resources used only if you use UART:
  • UART1
  • TX: GP4 (Pico UART1 RX)
  • RX:  GP5 (Pico UART1 Tx)
  • baud: 9600
  • UART1 RX interrupt
for UART, RX connects to TX and vice versa
Pico common resources:
  • RESET: GP18 (optional)
  • 5V: VBUS
  • 0V: GND
image: how to hook up the Teseo PCB to a Pico.
visit the github repository (git clone https://github.com/jancumps/pico_gps_teseo.git)
view the online documentation
Link to all posts.
