Embedded and Microcontrollers
Blog efficient sprintf() string format lib for lower range microcontrollers
  • Date Created: 4 Oct 2025 7:17 PM Date Created
  • Views 1164 views
  • Likes 10 likes
  • Comments 9 comments
  • MSPM0L1105
  • MSPM0
  • embedded
  • easyL1105
4 Oct 2025
I'm learning the ins and outs of an MSPM0 controller. I'm using an MSPM01105, that's low on power use. But also low on available memory.
I tried to use the standard C library's sprintf() function in a project, to format a string with a few integers. That's not possible. The function exhausts this Arm M0's resources.
So I went looking for alternatives. One of those is the printf library. It does a great job at delivering a lot of the stdlib functionality, cheaper. Of course, it's all based on compromises. But definitely usable.
Using printf
Your project will need 2 files: printf.c and printf.h. Once you add those to your project, you can start using the sprintf() function. It has the same formatting commands as the stdlib one. Just less options. That's what I use. I don't use this library to immediately printf() to UART. I use sprintf() to format memory buffer strings, that can later be sent by native buffered UART.
If you also want to use the printf() to print formatted text directly to UART,  you'll have to write a putchar_() function that knows how to output data to your UART. Else a printf() will do nothing.
Example:
#include "printf.h"
#define buf_len 16
#define fifo_len 4
char txPacket[buf_len];
void stream_data() {
    sprintf(txPacket, "[%+5i %+5i]\n", myIntA, myIntB);
    for(uint32_t i = 0; i < buf_len / fifo_len; i++) {
        /* Fills TX FIFO with data and transmits the data */
        DL_UART_Main_fillTXFIFO(UART_0_INST, &txPacket[0 + i * fifo_len], fifo_len);
        /* Wait until all bytes have been transmitted and the TX FIFO is empty */
        while (DL_UART_Main_isBusy(UART_0_INST)) ;
Lowering the footprint further:
If you don't need to format floats and exponential, you can set two symbols to 0:
PRINTF_SUPPORT_EXPONENTIAL_SPECIFIERS=0
PRINTF_SUPPORT_DECIMAL_SPECIFIERS=0
This takes care that the most expensive chunks of code don't get added to your project, if you don't need them.
Example
Here is example output, created with sprintf(txPacket, "[%+5i %+5i]\n", myIntA, myIntB):
thank you for reading.
Related posts
  • scottiebabe
    scottiebabe 11 months ago
    Nice. Got a new meter, but I can't recommend it yet... Has quirks.
    Jan Cumps 11 months ago in reply to scottiebabe
    LCR?
  • scottiebabe
    scottiebabe 11 months ago in reply to Jan Cumps
    Yes, an LC1020E
    Physical design, UI, etc is great for the price, not so sure about measurement performance yet...
    I spent 250 €  on mine.
    That FNIRSI sells for 1/4th the price down here. Cheaper from Aliexpress, but I have to pay import duties for every package these days.
  • scottiebabe
    looks like a nice meter, latest price seems to be €400+
    dougw 11 months ago in reply to scottiebabe
    Kelvin probes - nice....
  • scottiebabe
    scottiebabe 11 months ago in reply to dougw
    The kelvin clips work great on small resistors. 100kHz mode is wonky.
  • scottiebabe
