Embedded and Microcontrollers
Embedded Forum Power delivery IC
  • Replies 20 replies
  • Subscribers 505 subscribers
  • Views 5228 views
Power delivery IC
aster94
aster94 over 6 years ago
Discalaimer: I am an hobbyst, not a professional
I am looking for a IC that change the output from a USB-C from 5v to 12v. I was able to find a few IC (like STUSB4700 from STM but there are others) that can do this, but all the IC i found need to be connected to a master I2C. Since i run out of pins, and i would like an easier solution i would like to have a chip that can change the power delivery from the standard 5v to 12v. On aliexpress i found the IP2721 (see here: https://stackoverflow.com/questions/58666162/type-c-usb-c-trigger-set-lowest-voltage-allowed ) which is perfect for my needs but it has a chinese datasheet and doesn't seem easy t find.
Do you know any solution?
    Jan Cumps over 6 years ago in reply to aster94 +4
    Is this something you could use? USB-C Power Delivery Sink (CYPD3177)
  • aster94
    aster94 over 6 years ago +2
    At the end i bought the module with the IP2721 I am writing here just in case someone finds this topic because today i found the stusb4500 ( https://www.st.com/en/interfaces-and-transceivers/stusb4500…
  • wolfgangfriedrich
    wolfgangfriedrich over 6 years ago in reply to Jan Cumps +2
    Thanks, Jan Cumps . I saw this thread just now.
    dougw over 6 years ago
    MAX771ESAMAX771ESA
  • aster94
    aster94 over 6 years ago in reply to dougw
    I may have explained me wrong: I am not looking for a step up converter.
    I am looking for a USB-C power delivery controller that can be driven only with passive components
    shabaz over 6 years ago in reply to aster94
    Hi Vincenzo,
    What makes you think such a thing exists? If it does, it will likely be some hobby module. If google has not found it, I think it may not exist unfortunately.
    The STUSB4700 is an IC for the 'provider side'. It's part of the supply, not a device you use on the consume side to negotiate an output. STUSB1602 is a 'sink side' device.
    On the EEVblog, they are designing a µCurrent supply that uses Type-C PD. They have a hard time.
    It's possible to implement in a microcontroller. ST has a software solution for their controllers ...
    I haven't seen single-IC solutions that can get 12 V out of a USB-C connector just with passives. Maybe there's a market for that ...
  • aster94
    aster94 over 6 years ago in reply to Jan Cumps
    The IP2721 can do it, but i am unable to find it and anyway it's datasheet is in chinese. Maybe the usb-c and PD is just "new" and some ic are still waiting to be released...
  • aster94
    I am writing here just in case someone finds this topic because today i found the stusb4500 (https://www.st.com/en/interfaces-and-transceivers/stusb4500.html) which is very near to what i was looking for
  • wolfgangfriedrich
    Thanks, Jan Cumps.
  • seulater
    seulater over 6 years ago in reply to shabaz
    Google does not find everything, and should not be the "go-to" place for semiconductor searches. Distributors are the go to.
  • seulater
    seulater over 6 years ago in reply to Jan Cumps
    "On the EEVblog, they are designing a µCurrent supply that uses Type-C PD. They have a hard time."
    That does not mean anything The kid they have working there is not a seasoned engineer. He just got out of school, so dont put any faith on what they "can" or "cannot do"
