Embedded and Microcontrollers
Embedded Forum some ultrasound transducers (phased array)can anybody suggest
  • Replies 8 replies
  • Answers 3 answers
  • Subscribers 503 subscribers
  • Views 1326 views
anjub
anjub over 8 years ago
Hi, I have to design a ultrasound imaging system, can you suggest me transducers for the same
    dougw over 8 years ago +1 suggested
    I would look for the smallest ultrasonic transceivers - here is a waterproof example: http://canada.newark.com/multicomp/mcusd14a48s09rs-30c/transceiver-48khz-14mm-metal/dp/17X2009?st=ultrasonic%20transceiv…
    dougw over 8 years ago in reply to anjub +1 suggested
    Technically it could do something, but getting medical certification is a whole other question. Also if you want to do ultrasound or sonar in something denser than air, you might go to much higher frequency…
    I don't know about medical applications but these are about as cheap as I've seen for ultrasonic transducers in the MHz range: https://www.ebay.ca/itm/5pc-1-7MHz-Ultrasonic-Mist-make-Transducer-Piezoelectric…
    0 dougw over 8 years ago
    You may want a more uniform beam pattern depending on your geometry.
  • anjub
    0 anjub over 8 years ago in reply to dougw
    can it be used in medical imaging?
    0 dougw over 8 years ago in reply to anjub
    Also if you want to do ultrasound or sonar in something denser than air, you might go to much higher frequency transducers. Anywhere from 0.5 MHz to 6 MHz.
  • anjub
    Thank you ..
    can you suggest me some transducers which have been used in medical ultrasound imaging.
    0 michaelkellett over 8 years ago in reply to anjub
    You'll need to do some internet searching - you'll find that it's much harder to get information on medical imaging sensors than sensors for industrial purposes. I think that this is because the manufacturers of medical imaging equipment tend to make their own. I found a few research papers but mainly hidden behind paywalls.
  • anjub
    0 anjub over 8 years ago in reply to michaelkellett
    hi Micheal,
    You are absolutely right, its really hard to get information regarding ultrasound imaging transducers. Thank you so much for your efforts. Still if you find any of my need, please suggest.
    Anju
    https://www.ebay.ca/itm/5pc-1-7MHz-Ultrasonic-Mist-make-Transducer-Piezoelectric-Ceramic-Humidifie-D16mm/391975588349?ha…
  • anjub
    Thank you,
    Any transducers in your knowledge that have 16x16 number of elements ?
