Ask an Expert Forum Colorsound Power Boost - Another issue!!!
  • Replies 40 replies
  • Subscribers 338 subscribers
  • Views 7663 views
See a helpful answer?
Andy Betts
Andy Betts over 6 years ago
Hi guys,
Been a long time since I posted here and i have another issue for you that hopefully you might be able to help with.
I've just recently built another Power boost pedal for a client. I etched the board myself using the photo resist method, it came out not too bad save for a couple of areas where the tracks were broke. i patched them up with copper tape that has conductive adhesive. I've checked for continuity and all is fine where the patches are. Here are the pictures of the board and also for reference the schematic.
I've built a few of these now and have had no issues with the circuit or builds until now. I built this one, wired it to my test rig and there is no sound at all.... it's totally dead as if it's not in the circuit at all. I've checked for voltage on input and it's ok. I've checked for continuity in the circuit and it seems ok. i don't know what the voltages should be in the various sections of the circuit so haven't checked them. I've gone basic and checked the input and output wires for breaks and they're ok. I've also checked the test rig with a known good circuit and it's OK.
i think there might be a duff component but not sure on first steps to troubleshoot.... Any help will be greatly received.
    michaelkellett over 6 years ago in reply to Andy Betts +3
    What value is the blue bodied resistor - it looks like 1.8M brown grey green - if its meant to be 180k that would explain things. I could be being misled by pictures. MK
    Jan Cumps over 6 years ago in reply to geralds +3
    geralds wrote: ... Tip: use your finger as a signal injector. - You are a 60Hz (in AUT I'm a 50Hz sender ) sender "brummmmmm.....!!!""", so you can check the signal with a signal follower (mini-amp with…
  • Andy Betts
    Andy Betts over 6 years ago +3
    I've taken a higher res photo of the board.... this is how it stand now after reflowing the 3k9 resistor and bridging the break in the track on the Q3 base
    Could you measure the voltages on the collectors and emitters of the three transistors - that should provide enough information to get started.
    I take it that you don't have a scope and a signal generator ?
  • Andy Betts
    Andy Betts over 6 years ago in reply to michaelkellett
    Correct, I don't have either of those.... I'll check the voltages and advise
  • Andy Betts
    Hi Mike et al
    Voltages are as follows... I think Q3 is duff
    Q1 E = 5.83, C = 5.825, B = 5.83
    Q2 E = 5.15, C = 5.79, B = 5.79
    Q3 E = 0, C = 0, B = 0.58
    Not necessarily:
    You have base emitter voltage on Q3 that looks about right - if the emitter resistor or cap was shorted the transistor would be turned hard on
    and the collector voltage would be low (although not quite zero).
    If Q3 was collector/emitter short there would be a voltage across the 1k emitter resistor.
    If your DMM is up to it try measuring the resistance Q3 emitter to ground - should be 1k but only if the DMM uses a low voltage.
    Otherwise remove the cap and see what happens to the Q3 voltages. (I reckon duff cap more likely than duff resistor).
  • Andy Betts
    What cap do you suspect?? 4.7uf to ground from the emitter??
    Yep, that's my suspicion.
  • Andy Betts
    I removed the cap, and there's no change in the Q3 voltages, still E = 0, C = 0, B = 0.58
  • Andy Betts
    I replaced it with a brand new cap, and no change.. still dead as a dodo.
    dougw over 6 years ago in reply to Andy Betts
    Perhaps the 3.9K resistor on the collector of Q3 is not connected.
  • geralds
    geralds over 6 years ago
    On the bottom side of the board, if I saw right (the image is not right focused),
    it seems that the track around the 3k9 near to the Q3 is broken (across the track 2x over etched ) on two ends.
    And, please isolate the trimmers from the tracks.
    And, on the top side of the board there are two holes without a component. Is this right? Or must a resistor mounted there?
    Tip:
    use your finger as a signal injector. - You are a 60Hz (in AUT I'm a 50Hz sender image ) sender "brummmmmm.....!!!""", so you can check the signal with a signal follower (mini-amp with loudspeaker).
    Best Regards
    Gerald
