Ask an Expert Forum Colorsound Power Boost - Another issue!!!
  • Replies 40 replies
  • Subscribers 338 subscribers
  • Views 7663 views
See a helpful answer?
Andy Betts
Andy Betts over 6 years ago
Hi guys,
Been a long time since I posted here and i have another issue for you that hopefully you might be able to help with.
I've just recently built another Power boost pedal for a client. I etched the board myself using the photo resist method, it came out not too bad save for a couple of areas where the tracks were broke. i patched them up with copper tape that has conductive adhesive. I've checked for continuity and all is fine where the patches are. Here are the pictures of the board and also for reference the schematic.
I've built a few of these now and have had no issues with the circuit or builds until now. I built this one, wired it to my test rig and there is no sound at all.... it's totally dead as if it's not in the circuit at all. I've checked for voltage on input and it's ok. I've checked for continuity in the circuit and it seems ok. i don't know what the voltages should be in the various sections of the circuit so haven't checked them. I've gone basic and checked the input and output wires for breaks and they're ok. I've also checked the test rig with a known good circuit and it's OK.
i think there might be a duff component but not sure on first steps to troubleshoot.... Any help will be greatly received.
    michaelkellett over 6 years ago in reply to Andy Betts +3
    What value is the blue bodied resistor - it looks like 1.8M brown grey green - if its meant to be 180k that would explain things. I could be being misled by pictures. MK
    Jan Cumps over 6 years ago in reply to geralds +3
    geralds wrote: ... Tip: use your finger as a signal injector. - You are a 60Hz (in AUT I'm a 50Hz sender ) sender "brummmmmm.....!!!""", so you can check the signal with a signal follower (mini-amp with…
  • Andy Betts
    Andy Betts over 6 years ago +3
    I've taken a higher res photo of the board.... this is how it stand now after reflowing the 3k9 resistor and bridging the break in the track on the Q3 base
    michaelkellett over 6 years ago in reply to dougw
    Yes, that would do it - and explains 0V on the collector rather than Vcesat from a short in the emitter circuit.
    I think Gerald has found the break in the track.
  • Andy Betts
    Andy Betts over 6 years ago in reply to geralds
    The 2 holes are not required, they're for a different circuit. I'll check the tracking though and report back
  • Andy Betts
    I located the break and tested for continuity and it was fine... I did bridge it with solder though and tested the circuit again, still no cigar
  • Andy Betts
    Andy Betts over 6 years ago in reply to Andy Betts
    The pots are isolated, the rear of the pots have plastic covers to isolate from the tracks
  • Andy Betts
    Andy Betts over 6 years ago in reply to michaelkellett
    I'll check that and reflow the solder around that resistor... maybe its a cold joint
  • Andy Betts
    Andy Betts over 6 years ago in reply to dougw
    Hi Douglas, I checked that resistor and it was OK. I reflowed the solder anyway and re-tested with no change
    geralds  wrote:
    Tip:
    use your finger as a signal injector. - You are a 60Hz (in AUT I'm a 50Hz sender image ) sender "brummmmmm.....!!!""", so you can check the signal with a signal follower (mini-amp with loudspeaker).
    Get yourself a cheap computer speaker with amplifier (cheapest you can find), and you can use that to trace that hum that's generated by your finger.
    Cut off the audio plug. Solder the audio ground to your circuit audio ground and use the left or right input as a probe.
    Start at the first transistor, then move along with the signal path.
  • Andy Betts
  • geralds
    geralds over 6 years ago in reply to Jan Cumps
    Hi Jan, Jan Cumps
    Yes, so. This is what I thought about. image
