Ask an Expert Forum Colorsound Power Boost - Another issue!!!
  • Replies 40 replies
  • Subscribers 313 subscribers
  • Views 6231 views
See a helpful answer?
Andy Betts
Andy Betts over 5 years ago
Hi guys,
Been a long time since I posted here and i have another issue for you that hopefully you might be able to help with.
I've just recently built another Power boost pedal for a client. I etched the board myself using the photo resist method, it came out not too bad save for a couple of areas where the tracks were broke. i patched them up with copper tape that has conductive adhesive. I've checked for continuity and all is fine where the patches are. Here are the pictures of the board and also for reference the schematic.
I've built a few of these now and have had no issues with the circuit or builds until now. I built this one, wired it to my test rig and there is no sound at all.... it's totally dead as if it's not in the circuit at all. I've checked for voltage on input and it's ok. I've checked for continuity in the circuit and it seems ok. i don't know what the voltages should be in the various sections of the circuit so haven't checked them. I've gone basic and checked the input and output wires for breaks and they're ok. I've also checked the test rig with a known good circuit and it's OK.
i think there might be a duff component but not sure on first steps to troubleshoot.... Any help will be greatly received.
    michaelkellett over 5 years ago in reply to Andy Betts +3
    What value is the blue bodied resistor - it looks like 1.8M brown grey green - if its meant to be 180k that would explain things. I could be being misled by pictures. MK
    Jan Cumps over 5 years ago in reply to geralds +3
    geralds wrote: ... Tip: use your finger as a signal injector. - You are a 60Hz (in AUT I'm a 50Hz sender ) sender "brummmmmm.....!!!""", so you can check the signal with a signal follower (mini-amp with…
  • Andy Betts
    Andy Betts over 5 years ago +3
    I've taken a higher res photo of the board.... this is how it stand now after reflowing the 3k9 resistor and bridging the break in the track on the Q3 base
    Hello Andy,
    Now you have fixed the possible break in the track could you measure the voltages around Q3 again ?
    I'm very puzzled that you got 0.58 V on the base - which implies a base current, which ought to make volts across the 1k resistor. - but you saw 0.
    Might be time to take Q3 out and measure the voltages without it in circuit.
  • Andy Betts
    Andy Betts over 5 years ago in reply to michaelkellett
    Hi Mike,
    E = 0v
    C = 0v
    B = 0.59v
  • geralds
    geralds over 5 years ago in reply to Andy Betts
    As I asked yesterday, did you checked the transistor Q3? On top of that transistor seems that has a burning hole.
    Even if the transistor was a dead short in all directions it couldn't make these results because the emitter resistor would have current and therefor volts across it.
    I'm baffled.
    The only conclusion is that the rest of the circuit is not what the diagram says, due to a fault no one has spotted yet.
    The best I can offer you is that if you want to pop it in the post I can bring bigger guns to bear on it and see if I can fix it for you.
    Alternatively, with the power off, measure the resistance from base to earth, base to emitter, emitter to earth and collector to 18V.
    And let me know what meter you are using, because this may affect the results.
  • Andy Betts
    Andy Betts over 5 years ago in reply to geralds
    it's just a mold line.. nothing to worry about
  • Andy Betts
    I have an audio probe being made today... i'll have a go with that before doing anything drastic like posting it off to you
    Good luck, you could try the power off resistance measurements while you're waiting image
  • geralds
    Your meter, is this switched for DC_V measure, or AC_V?
    Normal on the Base of Q3 you can measure about 3V_DC..,. or a bit more, so 3,4V_DC in respect to GND.
    180(k) / 33(k) = 5.45 -> 18V_DC / 5,45 = 3,302 V_DC bias_V.
    If you don't measure somewhat here, GND -> R_Base, then one of the tracks is broken, or you have a "cold solder", solder is broken.
    What do you measure on all transistors?
    B-E, B-C, E-C, and all of them in respect to GND?
    Any of the polcaps, are they ok?
    The blue 180k resistor, is this really a resistor, not an inductance?
  • colporteur
    colporteur over 5 years ago
    What piqued my interest with your post was the comment "I've built a few of these now..."
    If you were sitting across the table from me sipping a cool one, I would suggest go online and get the board manufactured. The cost, other than the fk'ing shipping, is inexpensive. This is from the perspective of a retired guy living on fixed income.
    I have not only done what you have shown in great pictures by the way, but I have lived it. At one point, your board building technique was the only way to economically make personal projects. I would buy you a beer right now, if it would convince you to use an online service to make your printed circuit boards.
    If but nothing else buying boards from a manufacture you are not troubleshooting bad tracks. Then again self-flagellation is practised in many religious convictions why not technology.
  • geralds
    Edit:
    If the blue resistor is with a value about 1,8M, you have a factor of 1:54 with this voltage divider.
    1800/33 =54,54
    Then you measure 18 / 54,54 = 0,33003V_DC or similar.
