Ask an Expert Forum Have a question about ADCs or DACs? Ask our Expert, Nick Gray
  • Replies 118 replies
  • Subscribers 345 subscribers
  • Views 17212 views
  • expert
  • nick_gray
  • power
See a helpful answer?
ChristyZ
ChristyZ over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Nick Gray
Nicholas Gray
Nicholas has worked in the Semiconductor industry for over 30 years and has authored a number of published articles about data converters (ADCs and DACs) and signal integrity issues.
  • nickgray
    nickgray over 14 years ago in reply to e14 Contributor +1
    Hi, Ben, A couple of ADCs that should do well in your application with Hall Effect sensors are the ADS1146 and the ADS1255, both from Texas Instruments. I am sure that other suppliers probably have suitable…
  • nickgray
    nickgray over 14 years ago in reply to YT2095 +1
    The reason that you picked up radio signals when connecting a long wire antenna to the input is because the ADC had an input bandwidth that could pick up those signals. The sampling action of the ADC then…
  • YT2095
    YT2095 over 14 years ago in reply to nickgray
    just a quicky to let you know that I just bought 7x AD7822s`, all the others were SMD devices (Useless to me).
    they only cost £2 each from a fella in Israel.
    these should be sufficient for now as back-ups are always handy, and may even lead to some single use stand-alone devices later.
    Again, thank you for your help image
    edited to update: Scratch that, turns out the AD7822 were SMD devices also, so I canceled that and bought 4X ADC1175s` instead, I figure if I`m forced to go the SMD route I may as well have something I want and hopefully get a breakout bourd for it and solder it up without wrecking too many of them in the process.
  • nickgray
    You are most welcome. I am glad that I could help.image
    Nick Gray
    e14 Contributor over 14 years ago in reply to nickgray
    Thanks a lot Nick.
    Very interesting, and could be used for many other projects besides. I've been looking into it and have ordered a simple demo board.
    Kind regards, Ben
    Hi Nick,
    I have read the tutorial document you had previously linked to a user enquiring about analog switches.
    Perhaps you can help me understand something basic about the ADG419BZ analog switch. What is the maximum voltage that can be applied to the output pins (s1 and s2)? What would this information be listed under in the datasheet?
    Also, it says that the device can operate from a 12V single supply but can be remain functional to voltages as low as 5V. Does this mean I can apply 5V to the VDD pin?
    If you can help me on these points, I would be very grateful.
    Regards
    Rachel
  • nickgray
    Hi, Rachel –
    I am very happy to answer your  question on analog switches.
    The ADG419 is an analog switch from Analog Devices and is their version of the DG419 from Vishay Siliconix. The letters at the end of the device type indicate the type of package, temperature range and how the device is packaged (tape-and-reel, etc.).
    Most specifications for the “Operating Conditions” of electronic components can be found in the specification tables of the data sheet. However, analog switches often do not have input range on their data sheets. This is because it is assumed that the input can be anywhere within the negative and positive supply voltages of the product. Often the negative supply voltage is zero Volts. If you look at Figure 6 on page 7 of the ADG419 data sheet, you will note that, for a single supply, the curves show the “On” resistance from 0V to the voltage of the supply. This tells you that you can go to these limits. Figure 3 on the same page tells you that you allow the input voltage to go down to the negative supply voltage and up to the positive supply voltage. What may not be obvious from these graphs is that the input (or output) voltage is on the horizontal axis. VS is the voltage on either “S” input and VD is the voltage on the “D” input.
    Note that these figures indicate that the “on” resistance, which is the resistance between input and output, changes as the input voltage changes. This can lead to signal distortion if you are not careful. This is true of all analog switches.
    Yes, you can use this analog switch with a single 5V supply applied to the VDD pin, but from Figure 6 you will note that the “on” resistance that ranges between less than 60 Ohms to above 70 Ohms. This may or may not be a problem in your application. The Vishay Siliconix DG419 with a 5V supply has an “on” resistance that varies between a little over 30 Ohms to less than 50 Ohms, as seen in the plot at the top left of page 5 of that data sheet. The variation is larger than the Analog Devices’ product, but has a lower value. Which would be better for you will depend upon just what you are doing with it. If you are putting a fairly high quality AC signal through it (like audio, for example), I would prefer the analog device product because it has less variation (and percentage variation), so would give you less distortion (also, larger signals would mean more distortion). If you are passing only DC through it, I would prefer the Vishay Siliconix product because you would get less voltage drop across it.
    I do hope that this answers your question. Let me know if you need anything else.
    Nick
    I am making a temprature sensor using PT100, which outputs a change a voltage value for a corresponding temprature. This temprature is given to the ADC module of pic16f877a, i don't understand how to find an equivalent temp for a voltage i/p given to the ADC. Can you help me with this?( i know a look-up table is to be made, but how??)image
  • nickgray
    nickgray over 13 years ago in reply to e14 Contributor
    Hello, Vineeta –
    Forgive me if I provide too much information, but I want to be sure you understand how to properly use your PT100 RTD.
    PT100 is a term used to designate a platinum RTD (Resistance Temperature Detector) with a nominal resistance of 100 Ohms at zero degrees Celsius. A PT500 would have a nominal resistance of 500 Ohms at zero degrees Celsius and a PT1000 would have a nominal resistance of 1000 Ohms at zero degrees Celsius. The resistance of a PT100 increases as its temperature rises and decreases as its temperature is reduced. It is extremely important to realize that an RTD measures ITS OWN TEMPERATURE by changing its resistance. It is also important to note that current through the RTD will raise its temperature. This is called self-heating. Therefore, it is important not to drive an RTD with too much current. For a PT100 it is common to provide a current of no more than 1.0mA through the RTD to prevent self-heating.
    You can force a known, accurate current through the RTD and measure the voltage across it to determine its resistance (R = E / I). Or you can put a fixed, accurate resistance in series with the RTD and apply a voltage across this series combination. With the latter you will need to make two measurements: one across the fixed resistor and one across the RTD. You will determine the current through this series circuit by measuring the current through the fixed resistor (I = E / R), and determine the resistance of the PT100 RTD from this current (R = E / I). The latter is most often used because an accurate current source is a rather complicated circuit.
    Now that you know the resistance of the PT100, there are two ways to determine the temperature of the PT100. The first way is to use the formula T = 0.3661 * R. This is very simple, but produces an error of plus or minus 1.5% over the temperature range of -45 degrees C to +130 degrees C. This error is in addition to the specified tolerance of the PT100 and gets greater outside of the range of -45 to +130 degrees C. Platinum RTDs such as the PT100 come in various tolerances called Class A, Class B and Class C, and some manufacturers provide a tighter tolerance than these standard classes.
    To get better accuracy than with a formula, you need to use a lookup table. The lookup table is nothing more than a table of resistance values corresponding to RTD temperature. An abbreviated PT100 lookup table is shown here:
    °C
    R
    -40
    84.271
    -20
    92.16
    0
    100.00
    20
    107.794
    40
    115.541
    60
    123.242
    80
    130.897
    100
    138.506
    So, how do we use this table? If we measure a PT100 resistance of 107,794 Ohms, we look up that value in the second column of the table above and note that the temperature is 20 degrees C. But what if we measure a resistance of 110.53 Ohms? That value is not in the table. In this case we must interpolate between values that are in the table. We assume that the table is linear between 20 and 40 degrees C, which bracket the 110.53 value. We find that this value is 35.3% of the way from 20 degrees C to 40 degrees C. This means that the temperature is found to be:
                       20 + 0.353 * (40 - 20) = 27.06 degrees C.
    There would be some error due to the fact that the curve may not be linear between 10 and 40 degrees C. For this reason it is best to have as complete a lookup table as possible for high accuracy. A large lookup table, however, takes a lot of memory.
    I have tried to briefly describe the lookup table and how to use it, which I believe is what you asked. I also tried to give you some helpful information on using an RTD. I did not discuss the possible need to amplify the voltage readings and the possible problems of doing so (such as gain accuracy and amplifier offset and offset drift problems) and how to overcome these problems.
    I do hope this information helps.
    Nick Gray
    michaelkellett over 13 years ago in reply to nickgray
    @ Vineeta
    You can simplify things a bit when you measure the PT resistance with a series precision resistor.
    If you use the same reference voltage as the reference for the ADC and the resistors then it doesn't matter what the actual reference voltage is.
    Suppose the reference resistor is connected to between the reference voltage and the PT sensor and the other end of the PT sensor to the system  0V.
    The voltage at the mid point = (Vr/(Rpt + Rr))*Rpt.
    The ADC reading will be (ADCmax/(Rpt + Rr))*Rpt
    so Rpt = (Rr*ADC)/(ADCmax-ADC) where ADC is the ADC reading.
    And of course you don't need to use a look up table - you can get a very good result by using a polynomial expression to calculate the resistance at any temperature.
    I have  a nice lttle book published by Labfacility (The Temperature Handbook) which explains all this and more - they have a web site www.labfacility.co.uk and the little books used to be free.
    If you temperature sensor is any distance away from the ADC you will need  amuch more sophisticated arrangement so let us know if it is.
  • nickgray
    nickgray over 13 years ago in reply to michaelkellett
    @Vineeta
    Some very good points, Michael. Thanks for them. I would suggest using RA3 and and RA2 for the ADC reference. The polynomial equation to use can generally be obtained from the RTD data sheet.
    Nick Gray
    e14 Contributor over 13 years ago in reply to nickgray
    Thanks, Micheal and Nick!image  Will work on these points and let you know how it goes.
