Ask an Expert Forum Have a question about ADCs or DACs? Ask our Expert, Nick Gray
  • Replies 118 replies
  • Subscribers 345 subscribers
  • Views 17133 views
  • expert
  • nick_gray
  • power
See a helpful answer?
ChristyZ
ChristyZ over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Nick Gray
Nicholas Gray
Nicholas has worked in the Semiconductor industry for over 30 years and has authored a number of published articles about data converters (ADCs and DACs) and signal integrity issues.
  • nickgray
    nickgray over 14 years ago in reply to e14 Contributor +1
    Hi, Ben, A couple of ADCs that should do well in your application with Hall Effect sensors are the ADS1146 and the ADS1255, both from Texas Instruments. I am sure that other suppliers probably have suitable…
  • nickgray
    nickgray over 14 years ago in reply to YT2095 +1
    The reason that you picked up radio signals when connecting a long wire antenna to the input is because the ADC had an input bandwidth that could pick up those signals. The sampling action of the ADC then…
  • nickgray
    nickgray over 15 years ago in reply to viantro22
    Hello Viktor,
    I do see your question about trying to login. All you need to do to ask a question is to do whatever you did to ask about logging in. I look forward to answering your question once you post it.
    - Nick Gray
  • viantro22
    viantro22 over 15 years ago in reply to nickgray
    HI  NICK !
    I  WRITED  IN  YOUR  BLOG  and  email  YESTERDAY.
    OK !  I  REPEAT.
    I  DESIGNED  ADCs   with  function  amplitude  detector.
    THESE   ADCs  no  require  sample-hold  swich  and  anti-aliasing  filter.
    INPUT  SIGNAL   for  ADCs  is  RF ,  OUTPUT  SIGNAL  frequency  amplitude modulation.
    THESE   ADCs   may  be  to  apply  for  direct  conversion  receivers,power  meters, adaptive  signal  processing  chips.....
    I  WILL   WANT  TO  SEE   these  ADCs  as  high  tecnologic  products
    YOUR   OPINION  about  necessity   ADCs  with  function  AD   today  ?
  • nickgray
    Hi Viktor,
    I am sorry, but I am not at all sure just what this ADC is because you say the input is RF and the output is "frequency amplitude modulation". Are you doing both FM and AM, or what? You also say that this could be used for direct conversion receivers, which DEmodulate or detect, not modulate. I am sorry, but I am totally confused as to what your ADC does or how it may do it.
    As for amplitude detection, that is a rather simple thing to do and is already being done. Refer to National Semiconductor's ADC121C021, which has VMIN and VMAX registgers that hold the lowest and highest conversion results, which is effectively an amplitude detector.
    My opinino about the "necessity" of this function is that it could be very helpful for some applications, but an ADC that has this single function only would have very limited use. Other functions would have to be provided to make the product useful, as is done with the ADC121C021.
    - Nick Gray
  • viantro22
    2011/2/21 Nicholas Gray <messages@element14.com>
         image: element14<http://www.element-14.com/?CMP=e14notificationemail_header> Re:
    Have a question about ADCs or DACs? Ask our Expert, Nick Gray created by
    nickgray <http://www.element-14.com/community/people/nickgray> in *Experts
    • - View the full discussion<http://www.element-14.com/community/message/26809#26809
  • viantro22
    viantro22 over 15 years ago in reply to viantro22
    HI   NICK!
    NICK, ISEND  SHEMES   AND  DIAGRAMs  of  work   ADCs
    I  WAIT  ANSWER.
    MY  REGARDS
    VIKTOR  TROITSKIY
  • nickgray
    Hi Viktor,
    What you have designed is a tracking ADC (see http://www.opamp-electronics.com/tutorials/digital_theory_ch_013.htm just a little lower than half way down the page) that captures the peaks. The use of such a device would be a combination of digitization and AM demodulation. This does pretty much what a high speed converter does in the undersampling mode, so I do not see how it offers anything new. The difficulty here I see is that the clock rate must be the same as the AM carrier rate, which can be quite fast. Undersampling converters use clock rates much lower than the incoming carrier rate to do the same thing. So, I hate to say this, but I see no advantage to your design.
    - Nick Gray
  • viantro22
    2011/2/27 Nicholas Gray <messages@element14.com>
    • - View the full discussion<http://www.element-14.com/community/message/27508#27508
  • nickgray
    I see your latest figure, but you did not say anything about it. This figure does not change my thoughts on the circuit.
    - Nick Gray
  • viantro22
    HI  NICK!
    I  SEND  SHEET  WITH  COMMENTS ,REALLY  FIGURE  WITHOUT   COMMENTS ?
    NICK  SAY  ME, IN  POST   FROM  21.02 2011  NOT  COMMENT  TOO?
    MAY  BE  IT  IS  BECAUSE, I  SEND  POSTS  FROM  gmail
    VIKTOR   TROITSKIY
  • viantro22
    2011/2/27 viktor troitskiy <viantro2255@gmail.com>
    >> Experts* - View the full discussion<http://www.element-14.com/community/message/27508#27508>
