Ask an Expert Forum Have a question about ADCs or DACs? Ask our Expert, Nick Gray
  • Replies 118 replies
  • Subscribers 345 subscribers
  • Views 17184 views
  • expert
  • nick_gray
  • power
See a helpful answer?
ChristyZ
ChristyZ over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Nick Gray
Nicholas Gray
Nicholas has worked in the Semiconductor industry for over 30 years and has authored a number of published articles about data converters (ADCs and DACs) and signal integrity issues.
  • nickgray
    nickgray over 14 years ago in reply to e14 Contributor +1
    Hi, Ben, A couple of ADCs that should do well in your application with Hall Effect sensors are the ADS1146 and the ADS1255, both from Texas Instruments. I am sure that other suppliers probably have suitable…
  • nickgray
    nickgray over 14 years ago in reply to YT2095 +1
    The reason that you picked up radio signals when connecting a long wire antenna to the input is because the ADC had an input bandwidth that could pick up those signals. The sampling action of the ADC then…
  • viantro22
    viantro22 over 15 years ago in reply to nickgray
    HI  NICK!
    ADCs  with  fuction  RF(AM) DETECTOR  work  how  ordinary  sinchronous  amplitude  detector  and  create  only  ONE  DIGITIZED  IMAGE  SIGNAL (FIG.3), what essential simplify  filtering  of  signal.
    ADCs  with  undersampling mode (FIG.2)  work  how  downconverter  and  create  FEW  IMAGES,  what  oblige  application  complicated  anti-alians filters.
    THEREFORE,PRESENCE  ONLY  ONE  DIGITIZED IMAGE (FIG.3) IN  COMPARISON  WITH  FEW  DIGITIZED  IMAGES (FIG.2)  IT  IS  MAIN  ADVANTAGE  ADCs  with  function AM DETECTOR .
    CLOCK  RATE  THESE ADCs  DEPEND  FROM ELEMENT  BASE AND  WILL BE  GROW.
    NOW  ABOUT  TRACKING  ADCs.IN  YOURS  REFERENCE  NOT  SIMILAR  TRACKING  ADCs.
    IN  MY  POST  from  2011/02/21  show  THREE  TYPE  ADCs.
         FIG.1 SHOW  ADC  without  clock  generator  and  with  two  comparators for  input  signal.
         FIG.2 SHOW  ADC  with  clock  generator  and  with  two  comparators  for  input  signal.
         FIG.3 SHOW  HIGH SPEED  ADC  with  CHANGED  STEP  CONVERSION  and  four  comparators for
    input  signal.
         INPUT  SIGNAL  FOR  THESE  ADCs   RF/IF  AC  SIGNAL.
         OUTPUT  SIGNAL  amplitude  modulation (AM)  or  envelope  INPUT SIGNAL.
    THESE  PROPERTY  NOT  IN YOURS  EXAMPLES,THEREFORE  THAT  TOO  ADVANTAGE  ADCs  WITH  FUNCTION  AMPLITUDE  DETECTOR.
    MORE  DETAILED   ABOUT  ADVENTAGES  THESE  ADCs  in  direct  convesion  receivers  DISCUSSION
    IT   IS  POSSIBLE.
    BEST   REGARDS
    VIKTOR   TROITSKIY
  • nickgray
    nickgray over 15 years ago in reply to viantro22
    Hi Viktor,
    I believe that I now understand what you are saying, and it makes sense. I believe the problem will be sampling at the AM carrier rate. Timing will be very critical. If you think that overcoming the problems is practical, then I suggest you should write up your idea to protect a possible patent, then seek our a semiconductor manufacturer that may be interested. However, I suspect that no semiconductor manufacturer would want to buy your idea and develop it, but someone might buy it if it were already developed. It does sound like a good idea, but that it will be difficult to implement.
    Good luck and best regards,
    - Nick Gray
  • viantro22
    HI  NICHOLAS!
    I  WILL  WANT  TO  DO  YOUR   BIUSINESS  PROPOSAL.CAN  DO  I  KNOW  YOURS  @EMAIL  ADDRESS ?
    BEST  REGARDS
    VIKTOR  TROITSKIY
  • nickgray
    Hi Viktor,
    I am not really in a position to help with such a proposal. If you are not working for a company or associated with a university that can help, I believe that you need a good patent attorney that is very familiar with electeronic patents.
    Nick Gray
  • viantro22
    HI  NICK!
    I'm  sorry for persistence .I  ready   include  you  in  quality  of   author, if   you  find  possibility  advancement
    that. I  have  working  images.TO the  point, NICK, do  you   work  on  NATIONAL  SEMICONDUCTOR ?
    I  do  offer  him ,they  be  quiet ,may  be  they  no  understand , how  work  ADCs.NICK,  may  be  you  prompt   to  whom  of  managers  or   vice- presidents  appeal  with  similar  question(@email.address) .
    BEST  REGARDS
    VIKTOR  TROITSKIY
    .  I am trying to design a solar positioning  system  to control the  movement of a panel useing the cn7485 comparator  I need a  4 bit analog  to  digital  converter   to feed the 7485
    THANK   YOU  .TIM   td1022@yahoo.com
  • nickgray
    Hi Viktor,
    I am sorry that you have had trouble trying to sell your idea, but I know that you will probably not be able to sell it easily. In general, semiconductor manufacturers do not like to pay for ideas, but prefer to do their own designs. When they use a design similar to what is already available, they make changes to get around any patents. Of course, this is so they do not have to pay patent royalties.
    I have not worked at National Semiconductor for over 2 years, but did work there for 17 years. They do indeed understand ADCs and how they work and have designed many different types of ADCs. I know that they will never buy someone else's design, but I do not know whether they will even acknowledge that they had some communication from you. If they do not acknowledge any communication, it might be their way of avoiding any engagement with you so that, should they come out with something similar to your design, you would find it very difficult to make any claims agains them. This is my guess, but I do not really know. I suspect that just about any semiconductor company would do the same thing, but again, I do not really know. National Semiconductor has had such a large turnover in people that I do not even know who the designers and managers are at this point. All of my contacts there have left National.
    I am sorry that I do not really know how to offer you any guidance in this, but I wish you good luck.
    Nick Gray
  • viantro22
    2011/4/15 Nicholas Gray <messages@element14.com>
         image: element14<http://www.element-14.com/?CMP=e14notificationemail_header> Re:
    Have a question about ADCs or DACs? Ask our Expert, Nick Gray created by
    nickgray <http://www.element14.com/community/people/nickgray> in Experts- View
    the full discussion<http://www.element14.com/community/message/30273#30273
  • nickgray
    nickgray over 15 years ago in reply to e14 Contributor
    Hi Tim,
    In general, 4-bit ADCs (analog-to-digital converters are very high speed (hundreds of megasamples per second and higher) devices and expensive. I would look for an inexpensive 6-bit or 8-bit ADC and just use the 4 MSBs from it. This will be less costly than using an  ultra high speed 4-bit ADC. The reason that a really inexpensive ADC is adequate is because you will end up with more than enough accuracy for four bits and even the cheapest of today's 8-bit ADCs will perform well at the 4-bit level. The problem might be that today's loc speed, low cost ADCs generally come with serial output. This is to lower the packaging cost, which can be high with a parallel output. Here are some suggestions:
    From Analog Devices: AD7170BCPZ-REEL7AD7170BCPZ-REEL7, AD7478, AD7171BCPZ-REEL7AD7171BCPZ-REEL7, AD7468.
    From National Semiconductor: ADC081S021CIMF/NOPBADC081S021CIMF/NOPB
    From Texas lnstruments; TLC5510 (parallel output, twice the cost of those above)
    Having answered your question, I now offer what I think is a less costly solution. It certainly seems that you are considering a primaryly digital solution. I suggest an analog solution with two sensors placed within a fixture with two chambers side by side such that one light sensor is facing up in the bottom of each chamber. The chambers would be open only at the top and the side that is opposite from the other chamber. The output of the sensors would go to the "+" inputs of different analog voltage comparators (you can use a dual voltage comparator in a single package), Between the two sensors place a resistor, potentiometer and another resistor in series with each other. The two resistors connected directly to the sensor outputs could be 10 k-Ohms to 100 k-Ohms and the pot can be 50 k-Ohms to 1 Megohm. The arm of the pot and the "-" inputs of the two comparators are connected together. Between the output and the "+" input of each comparator put a 50K to 100K resistor for hysteresis to keep the comparators from oscillating.
    With the sun shining fully on both sensors, adjust the pot all the way to one end of its travel and confirm that one comparator output is high and the other is low. Adjust the pot all the way to the other end and confirm that the output conditions of both comparators have changed. If this does not happen, increase the value of the pot. Once you settle upon a pot value, adjust the pot to one side, again with light shining equally on both sensors. Then move the pot toward the center until one of the comparator outputs just barely changes state. Measure and record the voltage at the arm of the pot. Move the pot all the way to the other end of its travel and then move it back until the other comparator output just barely changes state. Measure and record the voltage at the arm of the pot. Determine the average of these two readings, then set the arm of the pot for that average voltage. Connect the comparator outputs to a system that will turn the positioning motor one direction when one of the comparators is high and the other low, and turn the motor in the other direction when the opposite is true for the two outputs. When the comparator outputs are the same, then the motor should not be driven. I will leave the design of the drive system to you.
    Good luck!
    Nick Gray
    Hi Nick,
    One of my students wants a simple, inexpensive, 2 channel D to A converter that will be easy to interface to Arduino (I2C, SPI, One WIre).
    I don't think he needs super high precision.
    What part do you recommend?
    Michael Shiloh
    KA6RCQ
    www.teachmetomake.com
    teachmetomake.wordpress.com
    Interested in classes? Join http://groups.google.com/group/teach-me-to-make
