Ask an Expert Forum Battery Charging using DC Motor
  • Replies 30 replies
  • Answers 12 answers
  • Subscribers 346 subscribers
  • Views 19923 views
  • battery_charge
See a helpful answer?
I have been trying to wrap this idea around my head that I can successfully charge a battery by using a DC motor.  Here is the example:  You have let's say a 16,000mAh 6S Lipo Battery.  This battery is your primary energy source.  This battery will power a brush-less DC motor.  When the DC motor is creating high RPM's, this energy would be used to recharge the primary battery, while also powering other components within the device.  In this example, the device housing these components would be a cooling fan for a motor design I am working on.
Is this possible?
If it is, one thing I concern myself with, is that the battery designs of today, mostly only have one connection, which is used to plug into the charger or to plug into the device you wish to operate.  If this is in fact possible, I would like to speak further with you on perhaps helping me develop a solution.  Thanks!
    jw0752 over 11 years ago +4 suggested
    Hi Dan, shabaz is correct. If you make a motor spin with a battery the energy comes from the battery and is converted to mechanical energy and heat in the motor. In order to charge a battery with a motor…
    jw0752 over 11 years ago in reply to mrsyfy +4 suggested
    Hi Douglas, Thinking outside the box is good. shabaz did a good job of summarizing and expanding my post. Certainly some energy can be recovered if there is a need for the energy and if it is economically…
    michaelkellett over 9 years ago in reply to empresario +4 suggested
    I am quite sure that you have NOT seen any such thing but it may be that some freak circumstances or clever tricks have deceived you. If you could describe what you have seen and better still offer pictures…
    0 balearicdynamics over 11 years ago in reply to mcb1
    I think that we should make an Arduino project demonstrating the Carnot cycle image with sensors it's not difficult to see the disperse entropy and why adiabatics are not straight lines ...
    0 jw0752 over 11 years ago in reply to balearicdynamics
    Hi Enrico,
    I have found that people who use their imaginations to try to come up with new ideas, even when they do not have an in depth background in the science, are often the source of new and innovative things. This is because they have not yet been taught what is impossible and they are free to go beyond the bounds of this restriction. I hope that Dan doesn't get discouraged as he asked his question in a very well written way and he did a good job instigating this discussion. If you proceed to use the Arduino to demonstrate the Carnot cycle it will be a very interesting project but you will have to give Dan some of the credit for the inspiration.
    0 balearicdynamics over 11 years ago in reply to jw0752
    jw0752 & Dan Walden
    in my opinion, you are true and not true (something like a shroedinger reality). Over the top irony should be always welcome, in my opinion.
    The idea was not to discourage you (Dan) as I spent months of my life when I was child to understand why what you have asked was not possible. Until someone has not shown me the illumination of the entropy principle. The point is that as far as what I see in a self-teaching path (I trust much in this approach, personally) it is best practice to search and acquire first what are - if any - the scientific rules beside something that is not simple to understand.
    I wrote:
    My general question is - how is it possible that someone tried to propose energy solutions, ANY kind of energy solution, without knowing the minimal, essential, laws that roles our part of universe?
    This does NOT mean "you should know before asking" but "be curious and search to see what is the point". I agree with mcb1
    Didn't you know you can find all the answers on the internet...they might not be right, but because they are there they must be.
    That is the sense of the question.
    Enrico
  • Capper
    0 Capper over 11 years ago
    Of course you can charge a battery from a dc motor, that's how generators work.  You just can't do it at the same time you're powering the motor.
    Look up regenerative brake "https://en.wikipedia.org/wiki/Regenerative_brake"
    Keep thinking,
    Scott
  • mrsyfy
    0 mrsyfy over 11 years ago in reply to jw0752
    Hello John,
    I enjoyed reading your post on thermal dynamics. When I was younger and did not have the training I have now. I too had the dream of making a perpetual motion device too. But since then, and with the advancements in the field of electronics its getting closer to that dream of coming true. Lets break  your explanation of thermodynamics down to its basic form. electrical energy - turns the motor and trans forms to mechanical energy - as a result of friction the mechanical energy produce heat which until now was unrecoverable. which results in energy loss. Just suppose there was a way to recover the heat loss and transform it back into electrical energy. I understand that we will not be able to totally recover all of the heat, but if enough was recovered and turned back into electrical energy. This was an Ideal I had but getting and understanding the same explanation you gave I let it go until I seen on inscrutables an article on how they are converting heat back into electrical energy. here is the link   Recycled Energy - $7.50 Generator! - ThermoElectric Generator. They use this generator to charge cell phones and tablets with a candle. I also understand that in small scale this Ideal is useless. But what about large scale like hydroelectric generators, or electric pole generators where a lot of heat is expelled?
    0 shabaz over 11 years ago in reply to mrsyfy
    Hi Douglas,
    Recovering energy from heat generated by the motor in its normal activity is not the same as using a motor to drive a generator, which was the question the original poster asked.
    The original poster had a battery supplying power to a motor which was performing some useful purpose (not mentioned - lets say perhaps driving a fan). In addition the original poster wanted to use the motor to also drive a generator to charge the battery back up. This actually would have resulted in less operational time before the battery needed a recharge,because of additional inefficiencies - therefore would have actually been worse than just using the battery to drive the motor to drive the fan in the first place.
    Regarding your point, yes if there are inefficiencies resulting in heat then that could be collected to allow the battery to run longer. Another option is to make the motor more efficient, e.g. with better bearings and better commutation. In some cases DC motors can be very efficient (more than 90%) so the motor would at best run for under 10% longer.
    For large scale generators I think they may already perform heat recovery. Businesses can also do things to recover this energy. There is a useful website here.
    It isn't. There are no advancements in the field of electronics that could achieve this.
  • mrsyfy
    0 mrsyfy over 11 years ago in reply to shabaz
    your right, I was just was just trying to break down the laws in which John had explained so well. To try to reclaim the heat loss and convert it back into a useable power source. and the only way I know to make a motor more efficient is to get rid of the friction created from the motor turning and the bearing rubbing on the two surfaces. one method would be super cooling or placing the motor in a vacuum. but for DC purposes are not feasible. so without finding a way to reclaim the heat loss or get rid of the friction, no there is no way at present recharge the battery with the motor as it is. I was just thinking outside the box.
    0 jw0752 over 11 years ago in reply to mrsyfy
    Hi Douglas,
    Thinking outside the box is good. shabaz did a good job of summarizing and expanding my post. Certainly some energy can be recovered if there is a need for the energy and if it is economically justifiable. In most cases the cost of the harvesting or recovery technology is more than the value of the return. By the way I think most of the heat loss in a motor comes from resistive and inductive losses rather than friction. 2AM here and time for me to shut down for the night.
  • screamingtiger
    0 screamingtiger over 10 years ago
    I wanted to add one thing to this discuss:
    Conservation of Energy.
    Once you understand that you will understand everything  image
    Lord  knows I can't lift myself into the air John
    Absolute classic! i just burst out laughing for no apparent reason as far as the people round me are concerned hah!
    On a serious note... like others have already said, the energy that turns the charging motor must come from somewhere, heres another example; Your car battery keeps its charge because of the alternator motor that spins from the cars engine.
    Its easy to believe that this energy is free because the engine is already running but in reality causes a small amount of drag, and wastes some energy through heat, light and sound. This results in the engine consuming more fuel, but its considered a worthwhile system cost to keep the battery topped up.
