Ask an Expert Forum Apollo 13 inside my car !  or how to get lower AMP for a heater ?
  • Replies 13 replies
  • Answers 4 answers
  • Subscribers 339 subscribers
  • Views 2168 views
  • heater
See a helpful answer?
redgreenblue
redgreenblue over 8 years ago
I'm having a problem with my car heater, which is completly dead. Yep houston we have a problem, winter is incredibly hard this year.  it's over -20 celcuis outside most of the time. While I wait for better weather to fix the radiator and not freeze my fingers till they droped,  I figure I can use for a while a small heater that could use the lighter switch.
The lighter switch is 12 volt @ 15 amps, which give me 180 watts.
I baught a pretty nice ceramic heater that use 120 volt @ 2.1 amps, which need 250 watts.
I know with a lower AMP the heater will generate less heat but on the other hand this is way better than having -15 cold inside the car, which would probably feel like being inside apollo 13 with no heat...
The heater is pretty simple, it use the AC to power the heater and use DC to power a fan.
The thing I'm not use to is to modify and work with AC.
So here plenty of pics that show how it's build and specs.
I'm wondering
1- does I need to modify the 3 ways switch  (off, lower, high)
or
2-I need to change the step down transformer on the circuit.
Thanks guys !
    jw0752 over 8 years ago +2 suggested
    Hi redgreenblue, What you are trying to do will be difficult as you are fighting design. Since the heater is designed for 120 VAC @ 2.1 Amps this means that the effective resistance of the heater element…
    jw0752 over 8 years ago in reply to redgreenblue +1 suggested
    Hi Sorry I didn't look at the pictures before I wrote the first time. I have looked now and so I hopefully won't have a red face this time. The heater actually has (2) heaters that can be hooked up together…
    jw0752 over 8 years ago +1 suggested
    I will bother you one more time. You mentioned that the heater is at 460 Watts when it is on high in the last posting. At 460 watts the heater would draw about 40 amps from the 12 volts. This would also…
  • redgreenblue
    0 redgreenblue over 8 years ago
    Hey guys
    you're funny...image
    So bottom line for anyone who has broken heater in a car, the solution is not electrical heater !
    The small 12 volt heater are not good and will never be enough.
    case solve !
    C ya.
  • the-dubster
    0 the-dubster over 8 years ago in reply to redgreenblue
    Whilst a 12V  ceramic heater may be ok for a chilly day, dealing with a frozen wasteland is going to require serious power. As has been discussed, getting big power from small voltages requires big current.
    Not particularly easy or cheap.
    If the issue is your water system on your car then it’s gonna require time, a garage, skills and warm clothing.
    If it’s purely the heater fan failing to move heat from the heater matrix into the vehicle cab then you can direct drive the blower fan (fan speed resistor packs die).
    Which is it?
  • the-dubster
    0 the-dubster over 8 years ago in reply to the-dubster
    As for being funny, John is a hoot, me not so much! image
