Ask an Expert Forum Repair Challenge: XBOX ONE S! (Beep on then beep off)
  • Replies 57 replies
  • Answers 7 answers
  • Subscribers 352 subscribers
  • Views 46015 views
  • xbox
  • helpme
  • repair
  • xbox one s
See a helpful answer?
lilithelotor
lilithelotor over 7 years ago
CLARIFICATION
YES, BEFORE STARTING WORK ON THIS OF COURSE I GOOGLED AND WATCHED SEVERAL VIDEOS (MOSTLY USELESS) AND READ RESOURCES ON COMMON XBOX ONE AND ONE S PROBLEMS.
  1. I tried the HDD in a PC, and it does show up as several NTFS partitions with files that all look fine.
  2. Blu Ray drive at least powers up and can insert and eject a disc.
  3. Tried the "cold mode hairdrier" trick to spin the fan manually. It's not the fan. The fan works.
All other components of the board seem to work. Just the system started up with a startup sound, and shut down with a shut down sound immediately after. Likely a protection being triggered.
Help meee!
Trying to figure out this XBOX One S issue: https://www.ifixit.com/Answers/View/523582/PSU+11... Any ideas?
It makes the start and then stop sound. Southbridge gets voltage. All 12V test points get voltage. Power rails to CPU suspiciously low resistance. Details in iFixit link.
I have an XBOX ONE S that I bought as “for parts” on eBay and the owner says it was kept in a clean house, etc. It is indeed clean inside. No signs of water damage.
The PSU is also fine. The APU had a TON of thermal grease all over the surface mount capacitors. I didn’t remove that yet but I did re-apply some arctic silver and I used a more reasonable amount.
The symptoms I see:
Console when plugged in does a few quick pulses to the APU fan. Is it trying to init?
Console when eject is pressed makes the eject sound, then the shutdown sound immediately after.
Console when power is pressed makes startup beep and then shutdown beep immediately after.
I don’t know what kind of issue I’m getting yet. Is there a JTAG interface or some way to do further diagnosis on this thing?
11.94V sounds perfectly fine for a 12V rail. Should I simpy try plugging a PC power supply into the motherboard to see if it will boot?
Any links or info on diagnosis would be appreciated.
Thanks in advance!
later
Aha! In the image you can see the CPU filter capacitor is registering just 1 ohm! The others are pretty low too but I bet if I remove that one it’ll at least boot. I have a server motherboard with a broken socket that I can steal capacitors from. Might replace the whole row if necessary.
later still
Looks like I was wrong. That capacitor I removed still offers up almost exactly the uf value on the tin. So that was another dead end. Hmm... One weird thing, all of the test points register 60Hz but not 110V. So thankfully the PSU isn't pushing wall socket voltage through. But that frequency is weird. My multimeter needs a charge though so I'll measure that again after it has.
The entire power area for the APU offers almost no resistance to the ground plane which is worrying. Again, need to charge that multimeter and re-check.
later again
Power on with no heatsink, the processor doesn't even warm to the touch. CPU, GPU, and other test points around the board pulse to 1-2V and then turn off fast.
Can't help but think it's related to the very low impedance between ground and positive on the V rails for the CPU/GPU. Is that normal?
USB port is charging the multimeter image
So that 5V rail from the southbridge is working.
Lots of 12V test points are consistently 12V (11.94V)
So...
Does any one have a diagram of the test points around the motherboard? What voltages / values should I be seeing? What are some likely culprits?
Thanks in advance! You're all wonderful!
This is the original XBOX One. Similar, but not exactly what I need. I can still maybe work from it.
  • Gough Lui
    Gough Lui over 7 years ago in reply to lilithelotor +5 suggested
    Sorry - I've been quite busy and am at work ... supposing you didn't lift any traces or warp the board significantly, you might well be fine. However, that's not to say that the VRM didn't fail for other…
  • lilithelotor
    lilithelotor over 7 years ago in reply to Gough Lui +4 suggested
    You are so wonderful and I can't thank you enough. I will work patiently from now on and I have learned a lot from this process. It is actually the first time I have ever used my hot air rework station…
  • Gough Lui
    Gough Lui over 7 years ago +3 suggested
    Most of the time, VRM issues are blown MOSFETs which have become shorted - your low resistance measurement is suggestive that the MOSFET on that phase may have gone shorted. Short burst of voltage and…
    0 shabaz over 7 years ago in reply to lilithelotor
    Exactly, I'm not convinced it is a dead short yet - but we're still having the conversation. Maybe someone will interject and correct me since I'm only assuming that 1-2 ohms may be acceptable.
    If you take the device to a repair shop, they will have that conversation but you just won't hear it. Here it's in the open.
    Replacing a MOSFET is one thing, but powering up with it removed is very different. That wasn't anyone's advice, and anyway these are just suggestions - I don't know how many xbox experts are online here, so the suggestions are sometimes a bit more vague and general, unless people are 100% sure - and right now I'm not, but maybe others are.
  • lilithelotor
    0 lilithelotor over 7 years ago in reply to shabaz
    I agree about not powering it up, and would love if we could move on from that point. image
    I thought a good strategy might be to remove components that are likely to fail and test for grounding out again without them.
    That strategy may work, but there are risks along the way. I can't assume your experience level, and I may repeat myself at times to emphasise the importance of some points. I didn't mention how severe such a thing (that shall not be repeated) could be, so I'm afraid I chose to repeat it.
    Also, you'll find some engineers ask a lot of seemingly obvious questions like "was the hard drive checked" - because they do not know you, and from experience plenty of people say things like "I checked everything" when clearly they have not. I'm not suggesting that is you - I'm suggesting that I have no way of knowing, so sometimes people ask twice, in different ways.
  • lilithelotor
    My experience level with electronics is pretty basic but I did take the time to research common XBOX problems before I started removing parts. Yes. image
  • lilithelotor
    0 lilithelotor over 7 years ago in reply to lilithelotor
    Gough Lui shabaz
    Hi friends! You have been quite helpful. Thanks very much!
    I think I am ready to go buy some parts and see if I can make any difference with this thing. I'm having fun here so I want to keep trying to fix this thing.
    My next steps:
    1. Order some replacement parts
    2. Replace all of the parts in the power rails at once
    3. Try with power on again with all parts present
    Those are the parts I know of. To figure out what a surface mount capacitor is if it's unmarked, would it make sense to remove a few of them and average the capacitance value of them? Are they polarized if they are not marked? (I can make note of how they're connected to ensure I test the right polarity with them removed from the board.)
    I figure if I'm going to bother with the MOSFETs, I may as well buy a bunch of surface mount capacitors and resistors too to play with. I can then replace those too and make sure everything is within spec.
    Again, I understand spec is hard to understand without a known good XBOX One S motherboard to compare to.
    Do you have any advice for this stage?
    - Lil
    Unfortunately I only have general info, I don't know what others would do, but I would assume all resistors are working, unless I knew the board may have been bent, or if there was discoloration - I've never seen a resistor fail otherwise. But if you wish to replace or test it first, out-of-circuit measurement should match to within a few percent of the marking on it (some tiny resistors will have no marking). The last digit is usually the number of zeros to add to the previous digits.
    For surface-mount capacitors, those are ceramic types, and they don't fail in operation either, although they can definitely fail if cracked, e.g. heated from one end or flexed. I believe that is far more likely with tiny capacitors, i.e. millimeter-sized, which these ones are not in the photo (at least, I've only succeeded in damaging the tiniest capacitors in that way - but I could be making an incorrect assumption) or those in vibrating/flexing environments. The largest ones in the photo may be anything from 1uF to 10uF or something, but it's a huge guess, and any IC datasheet for the DC-DC converter circuit should be checked. Probably the voltage rating for them is 6.3-10V, but there is no way to be 100% sure. The smaller capacitors I have no idea, it would be too much guesswork, they could be 100nF or 10nF or anything else, and it needs the IC datasheet to be consulted, or a known working one to be measured. Sometimes that is luck, since the entire part number won't be marked on the IC - so google may help on that, or if anyone has a components list in that area. Also, those capacitors are likely of type 'X7R'. Often the larger ones are not cheap. If you think one is faulty, then the capacitance of a known working one could be measured out-of-circuit (since the three DC-DC converter circuits look identical - they are just set at different voltages). The capacitors are likely identical value, to reduce BoM costs. The values of the capacitors could vary by say 20% and still be fine - they have this variation from new, it won't be a fault causing this.
  • lilithelotor
    From what I can tell, I might have jumped the gun guessing a power issue. It might have been doing a boot loop due to the APU needing to be reflowed. I tried to do that, but I didn't give it much heat and it may have failed to reflow the solder. It may be the APU actually dead, but that's pretty rare.
    It seems to be a VERY common problem with the XBOX One S that the system will get into this state of "start up sound" then "shut down sound".
    Others on the Internet seem to think it's APU related.
  • tronicsfix
    0 tronicsfix over 7 years ago in reply to lilithelotor
    Have you given up on this project? I get these in all the time and while quite often they are fixable, sometimes they aren't. Just wondering if you ever figured out the problem for sure. Let me know if you get a chance.
    Thanks!
    Steve
    I don't know what the APU is, but if it is a physically big chip, it will be extremely difficult to reflow without specialist tools and procedures. You can check out 'Louis Rossman' videos on YouTube to see if he shows how to do large chips.. it's a specialist thing.
    I did see for PlayStation repairs, full-blown ovens are used for similar repairs, to get the heat energy to the whole of the large chips (aluminium reflective covered baffles protect the rest of the PCB). Another option could involve a pre-heater.
    With no experience myself on anything larger than 1cm2, so take this opinion with a pinch of salt, I think chances are near-zero with a large chip and just a low-cost handheld hot air tool. Even at 1cm2 I use a pre-heater, since my handheld hot air tool is only a few hundred watts.
  • keke12
    0 keke12 over 7 years ago
    MOSFET is toshiba TPN8R903NL IC is TPCA8A11
