Ask an Expert Forum Repair Challenge: XBOX ONE S! (Beep on then beep off)
  • Replies 57 replies
  • Answers 7 answers
  • Subscribers 352 subscribers
  • Views 46024 views
  • xbox
  • helpme
  • repair
  • xbox one s
See a helpful answer?
lilithelotor
lilithelotor over 7 years ago
CLARIFICATION
YES, BEFORE STARTING WORK ON THIS OF COURSE I GOOGLED AND WATCHED SEVERAL VIDEOS (MOSTLY USELESS) AND READ RESOURCES ON COMMON XBOX ONE AND ONE S PROBLEMS.
  1. I tried the HDD in a PC, and it does show up as several NTFS partitions with files that all look fine.
  2. Blu Ray drive at least powers up and can insert and eject a disc.
  3. Tried the "cold mode hairdrier" trick to spin the fan manually. It's not the fan. The fan works.
All other components of the board seem to work. Just the system started up with a startup sound, and shut down with a shut down sound immediately after. Likely a protection being triggered.
Help meee!
Trying to figure out this XBOX One S issue: https://www.ifixit.com/Answers/View/523582/PSU+11... Any ideas?
It makes the start and then stop sound. Southbridge gets voltage. All 12V test points get voltage. Power rails to CPU suspiciously low resistance. Details in iFixit link.
I have an XBOX ONE S that I bought as “for parts” on eBay and the owner says it was kept in a clean house, etc. It is indeed clean inside. No signs of water damage.
The PSU is also fine. The APU had a TON of thermal grease all over the surface mount capacitors. I didn’t remove that yet but I did re-apply some arctic silver and I used a more reasonable amount.
The symptoms I see:
Console when plugged in does a few quick pulses to the APU fan. Is it trying to init?
Console when eject is pressed makes the eject sound, then the shutdown sound immediately after.
Console when power is pressed makes startup beep and then shutdown beep immediately after.
I don’t know what kind of issue I’m getting yet. Is there a JTAG interface or some way to do further diagnosis on this thing?
11.94V sounds perfectly fine for a 12V rail. Should I simpy try plugging a PC power supply into the motherboard to see if it will boot?
Any links or info on diagnosis would be appreciated.
Thanks in advance!
later
Aha! In the image you can see the CPU filter capacitor is registering just 1 ohm! The others are pretty low too but I bet if I remove that one it’ll at least boot. I have a server motherboard with a broken socket that I can steal capacitors from. Might replace the whole row if necessary.
later still
Looks like I was wrong. That capacitor I removed still offers up almost exactly the uf value on the tin. So that was another dead end. Hmm... One weird thing, all of the test points register 60Hz but not 110V. So thankfully the PSU isn't pushing wall socket voltage through. But that frequency is weird. My multimeter needs a charge though so I'll measure that again after it has.
The entire power area for the APU offers almost no resistance to the ground plane which is worrying. Again, need to charge that multimeter and re-check.
later again
Power on with no heatsink, the processor doesn't even warm to the touch. CPU, GPU, and other test points around the board pulse to 1-2V and then turn off fast.
Can't help but think it's related to the very low impedance between ground and positive on the V rails for the CPU/GPU. Is that normal?
USB port is charging the multimeter image
So that 5V rail from the southbridge is working.
Lots of 12V test points are consistently 12V (11.94V)
So...
Does any one have a diagram of the test points around the motherboard? What voltages / values should I be seeing? What are some likely culprits?
Thanks in advance! You're all wonderful!
This is the original XBOX One. Similar, but not exactly what I need. I can still maybe work from it.
  • Gough Lui
    Gough Lui over 7 years ago in reply to lilithelotor +5 suggested
    Sorry - I've been quite busy and am at work ... supposing you didn't lift any traces or warp the board significantly, you might well be fine. However, that's not to say that the VRM didn't fail for other…
  • lilithelotor
    lilithelotor over 7 years ago in reply to Gough Lui +4 suggested
    You are so wonderful and I can't thank you enough. I will work patiently from now on and I have learned a lot from this process. It is actually the first time I have ever used my hot air rework station…
  • Gough Lui
    Gough Lui over 7 years ago +3 suggested
    Most of the time, VRM issues are blown MOSFETs which have become shorted - your low resistance measurement is suggestive that the MOSFET on that phase may have gone shorted. Short burst of voltage and…
  • paulohcampos
    0 paulohcampos over 7 years ago
    Did you managed to fix it? I have thr same problem and going througb the same path apart from replacing all the mosfets and capacitors...
    Tks!
  • jvpro
    0 jvpro over 7 years ago
    Hey guys if you guys make a request to iCustomiPhone on Youtube he will find the problem right away I'm having the same issue if we get at least 5 people telling him to make a video.
  • johnnydel
    0 johnnydel over 7 years ago
    Great challenge.... Yet I feel more joy in playing
  • ijaved
    0 ijaved over 7 years ago in reply to lilithelotor
    I just got one of these... did you manage to change the ic ?
    0 shabaz over 7 years ago in reply to ijaved
    Hi Javed,
    What IC are you referring to? If you're referring to the APU (large chip), there's no hope without specialist equipment, to remove and replace that.
    We're talking the cost of multiple Xbox units. You'd ideally need a specialist oven costing $1000 or more.. (and a lot of experience using it).
  • ijaved
    0 ijaved over 7 years ago in reply to shabaz
    I am talking about the controller chip highlighted there i think its the pic you sent couple of posts able. I do not have any voltage when i put red probe on gate and black on resistor. image
    black on gate registers .680ish so i am leaning towards the controller being bad?
  • changedsoul
    0 changedsoul over 7 years ago
    I just recently purchased an XBox One S off ebay that had water damage. I was attempting to repair it when much to my surprise, someone had already had a go at it and butchered it up a bit. Watching some videos on youtube i came to the conclusion having a power supply that has current limit ability is invaluable. It makes it very nice to track down shorts and fix them.
    My issue however is a bit worse than yours. I get no power on/off beeps. Checking the voltages, I have 12v, 5v, 3.3v(one of them), 1.8v all present. The board was shorted at the connector where the front panel connects (power, eject, etc) go. It was so badly damaged that I cannot tell what voltages are supposed to be present there. I was "hoping" this post is still somewhat active and someone can assist in these measurements?
    We may very well have a similar issue, but until I can repair what has been trashed, I dont know what is causing my issue.
    If someone would be super kind, and if possible, could someone tell me what voltages should be present on that connector at the bottom middle of the board, on Pin 8, and 7? This is where my board short was and I had to dig out the rot. Now I am left is a mess and need to connect the connectors to what ever power they were getting so I can see what else may be wrong. Pin 8 looks like it may be ground, and Pin 7 looks like it may be coming from that right cap (which I think is 5v),  but before I go and repair it, I would be so grateful if someone could verify the values for me?
    If I can get this working, I will post the solution, and just maybe it will solve the OP issue. I really hope its not the APU
  • blockaboots
    0 blockaboots over 6 years ago in reply to changedsoul
    I have a similar issue with my Xbox One S, basically the fault was the mosfet on phase line 3, i was getting a reading of only 0.357v each way with the Multi-meter, when in theory the reading should be 0.648v one way and then 1.917v the other. After i replaced the suspect mosfet i tested with the MM again but i was getting the exact same reading (0.357v). Any ideas why this might be?
  • lilithelotor
    0 lilithelotor over 6 years ago in reply to ijaved
    Hi there ijaved!
    I forgot about this project. I still have the board sitting in a cabinet in my work room.
    The component you are pointing to in the image is a MOSFET. It is quite possible it has failed. They are very delicate inside despite the fact that they work on huge currents.
    I think I destroyed my XBOXONES so I am not sure if I can be much help. I also made use of the HD and PSU for other projects. (I used the PSU to power a video card on one of those M.2 to PCIe16x adapters.
    shabaz  is really smart and so is Gough Lui
    Read what they wrote above in response to my comments and it might help you.
    Hope this helps!
      - Lil
  • lilithelotor
    0 lilithelotor over 6 years ago in reply to blockaboots
    My only thoughts would be a short elsewhere on the board. I know mine looks like it had minor water damage. Maybe it had been shorted somewhere along the way.
