Ask an Expert Forum Miller Boost Circuit Board Assembly NO. 200841
  • +1 person also asked this people also asked this
  • Replies 60 replies
  • Answers 3 answers
  • Subscribers 344 subscribers
  • Views 21931 views
See a helpful answer?
lanuser
lanuser over 7 years ago
Hello everyone,
Let me tell you small story image
While back I have purchased dead  "MIller Dynasty 200DX"
After some repairs I have found damage to Boost Board that has internal ground planes  burnedout.
I have realisedthat i would need board replacement, however, board is dicontiniued and replacement board will cost me 2000 dollars if I found one.
After fiew hundret emails  and phone calls to different suppliers without even one ansfer I have desided  recreate board from scrach and make my own.
Fiew month later after reverse engineering pcb to schematic  and later on from schematic to PCB i have finally received new boards.
I have solder necesseryparts and run test on new assembled board, however, I have forgot take a maguments from resistor R86
Could some one be so kind and provide value number between pin 2 & 3 on R86?
Here is some pictures from original board and final my creation:
    jw0752 over 7 years ago +3
    Hi Alex, Reverse engineering a board of this size and complexity is a monumental task. Congratulations on what you have accomplished. Sorry I don't have the information you are looking for but your work…
  • lanuser
    lanuser over 7 years ago in reply to jw0752 +3 suggested
    Josh, First of thank you for your reply. Is to easy to reverse engineering this board, however, it is time consuming a speacially when team of one working on entire project. I'm planing some changes for…
  • A3JBNE
    A3JBNE over 4 years ago +2 verified
    The value of R86 as it says in the technical manual adjusts the limit for the line current, by default it is approximately 10 ohms. R86 makes a voltage divider with R99 adjusted from 0 to 7.5V approximately…
  • A3JBNE
    0 A3JBNE over 4 years ago in reply to johnconnor
    (R6 = 0.27ohms 3W) (R7 = 1.5K) (C5 = 1nF) (Q3 = 2n3904 NPN)
  • kkazem
    0 kkazem over 4 years ago
    Be aware that you can't usually measure a resistor value in circuit and use that as a basis for a replacement part. The reason is that in most cases, the in-circuit resistor to be measured/replaced interacts with other components and the ohmmeter will read a value that may be very far off of the actual resistor value. To get past this, you can simply lift-up (isolate) one lead and then measure the resistor and that will be accurate. Alternately, you can completely remove the resistor and measure it with an ohmmeter.
  • mb443
    0 mb443 over 4 years ago
    Hi Alex, how is your progress? Did you get it to work? Seems many here would love to hear details. if you can share schematic and board file see if you can please link/upload here, also let me know how I can drop you some money to compensate some of your time.
    Best regards, Mike
  • lanuser
    0 lanuser over 4 years ago in reply to mb443
    Hello mb443
    Board is fully functional and yes I have schematic and gerber files, however,  to avoid legal actions I cannot release schematic to the public.
    PM me with any questions.
    Seems Element14 fixed their push email issue and now I started receiving  3 year old post and reply....
  • lanuser
    0 lanuser over 4 years ago in reply to johnconnor
    I bet there is more than just G4PH50UD shorted.
    Also, I would not advise purchasing used miller DX 200 series equipment.
    If IGBT toast you will be SOL.... used part from China will cost you $400-500 since there is no datasheet for IGBT and replacement new part from Miller will cost you arm and the leg...... and even that not guarantee part availability.
    After little research I would NEVER purchase another Miller equipment! There is way better solutions for Home project and for serious construction companies as well.
  • lanuser
    0 lanuser over 4 years ago in reply to alvideo
    Potentiometer contains 3 pins in total.
    By design pin 1&2 on PCB connected together I would need value between pins 2 & 3.
    Thanks in advance.
  • lanuser
    0 lanuser over 4 years ago in reply to kkazem
    Fully aware regarding getting resistor value in the circuit.
    Since this is potentiometer I would need value while in the circuit, however, ask someone to unsolder part to check the value and solder back in  will be crazy request.
  • lanuser
    0 lanuser over 4 years ago in reply to A3JBNE
    I do not know where you'll able to get your information, however, you are correct R86 designed for IGBT control on main power distribution board.
    The reason I request information because I do not  want for voltage overshoot at initial power on.  Main IGBT hard to come by now days.
  • guillermo
    0 guillermo over 4 years ago in reply to A3JBNE
    hi Mister,
    I was able to repair the two cards of the Dynasty 200, BUT I had the unpleasant surprise that the machine did not work when I turned it on.
    I followed the Pre-Power Check procedures manual and the igbt controlled PM1 is damaged (PC2 board). (Semikron SKiiP 33NEC125T2). attached photos.
    Do you know who can sell it?
    From already thank you very much.
  • guillermo
