Ask an Expert Forum My pin crimping tips -- what are yours?
  • Replies 26 replies
  • Answers 14 answers
  • Subscribers 341 subscribers
  • Views 17907 views
  • pins
  • crimping
  • crimper
See a helpful answer?
Sean_Miller
Sean_Miller over 7 years ago
I am a self taught pin crimper.  Sounds like a personal problem, I know.
I have a crimper tool that looks like this:
I use it to crimp pins for proto board soldered wire-to-board connectors that look like this:
At first, I was unhappy with the results due to the following results:
  • The wires would stab through the hole blocking the male end
  • I’d lose the pin from it falling off the cable before I could crimp it
  • the pins are hard to seat into the connector
  • the pins back out of the connector when connected to the male end
  • the wire breaks off at the base of the pin
  • the male pins would not want to stab into the female after everything was crimped and ready
<EDIT:  See this post below for the crowd improved troubleshooting guide:  https://www.element14.com/community/message/284233/l/re-my-pin-crimping-tips-what-are-yours#284233 >
Here's how I adjusted my approach:
IssueSolution
Wires stabbing through the holeI bend the wires back over the insulation
Dropping the pinI’d pre crimp the bottom with just my fingers to hold it in place.
Hard to seatAfter crimping the bottom of the crimp pin to the cable sheathing, I take a small plier to shape the female tip to remove any parts sticking out impeding entry into the plastic connector housing.
pins back outAfter adjusting the pin shape in the previous step, I pull up the tab that will catch inside the connector to prevent it from backing out.
the wire breaks offI stopped using jumper cables as the donor wire.  Instead, I use ribbon cable.
Male pins not fittingI use a single jumper male pin to pre stab in the female pins I just inserted into the connector to open it back up.
I now get reasonable results, but what bothers me is that I have to do all this.  I would think I could just crimp and insert and be done.
So, my question is, what are the community members experiences, steps, and tricks for using crimp pins?
Sean
    michaelkellett over 7 years ago in reply to fmilburn +6 suggested
    That's a good link , Frank. @Sean As you'll see from Frank's link, bending the inner back over the insulation is wrong. It sounds to me as if you are using the wrong tool for the crimp, and stripping off…
  • Sean_Miller
    Sean_Miller over 7 years ago in reply to fmilburn +6 suggested
    Thanks for linking that thread, Frank. All that shop talk was happening on my birthday. Funny thing was, I was probably trying to crimp pins and missed it. Looks like the one twist I had from Shabaz's…
  • fmilburn
    fmilburn over 7 years ago +5 suggested
    Hi Sean, My experience is similar to yours. There is a good discussion here: https://www.element14.com/community/message/276825/l/re-creating-dupont-equivalent-crimp-terminal#276825. Several people give…
  • dpenny
    0 dpenny over 5 years ago in reply to Sean_Miller
    Am new to using molex pins/sockets. Am hobbist doing 5-10 pins per year manually - oh well. Bought pins and housing from Amazon. Pins come attached to a "carrier strip." (dont know what else to call it)
    Am having probs getting pins to seat into the housing. Using 093 2-pin sockets with 18 ga lamp wire. My crimps on wire and insulation look good but cannot push into housing cause of "flaps" from carrier strip. If I trim flaps same as body width of pin, then the pin pulls out forward as I connect/disconnect housing pairs. If I leave trim flaps from carrier strip, I cannot push pin into housing.
    I have seen lots of stuff on web about crimps to wire and its insulation, but NOTHING about how to trim these carrier strip flaps.
    Advice needed.  I am having a 30% failure rate.
  • Andrew J
    0 Andrew J over 5 years ago in reply to dpenny
    Pictures might help but when I cut a pin off the carrier strip, I cut the carrier strip leaving a small 'tab' on the end of the pin.  After crimping, I cut this 'tab' off at the top of the pin and don't leave any of the carrier strip attached to the pin at all.  It's not really clear what you mean by 'flaps', perhaps you could post some pictures.
    0 shabaz over 5 years ago in reply to dpenny
    The carrier strips are for machine feed, but should be totally removed, as Andrew mentions.
    If the crimping action using your tool has left the wire grip portion too wide to fit the housing, then it can be gently re-shaped after crimping using needle-nosed pliers. For insertion into the housing, 18 gauge wire is so thick it should be almost effortless to push the wire and terminal into the housing.
    It needs photos, otherwise there's not a lot to go on.
    Also, those .093" crimp pins/sockets use a Molex-specific tool, and a lot of generic ratchet crimp tools will not do a good job on them. But at a pinch, I've had success with various tools for the few times I've used .093" crimps.
    I just used a non-insulated terminal crimp tool like HT-230CHT-230C (it is cheap, but totally the wrong tool, it is intended for uninsulated blade and ring crimps) and it crimps the wire portion just fine, but doesn't do a great job on the insulation grip portion, it leaves that too loose. So I redo the insulation portion using a non-ratchet tool (those are even cheaper). The end result works for me, and it pushes into the housing with no issue.
    I just tried it, this is with 16 AWG wire because I didn't have 18 AWG. I used the HT-230C tool, center crimp die. The insulation grip was too loose as expected, so I used a non-ratchet tool for that (it cost $6 or so from Fry's, intended for D-sub connectors, but unfortunately not sold any more - however a tool called HT-202B looks very similar but I cannot guarantee it is the same).
    Anyway, this crimp will perfectly fit the .093 housing just by pushing from the cable, and it doesn't come out with any amount of force that I can manage.
  • dpenny
    0 dpenny over 5 years ago in reply to shabaz
    Hope I can figure how to add photo herein. First image comments.
    A. shows good crimp and flaps folded otherwise I cannot insert pin.
    B. shows flaps trimmed not yet folded. Tried 2 ways: without folding cannot insert pin, with folding pin pulls out of FRONT as I take apart male/female connectors.
    C. shows pins as purchased.
    The crimp terminals are also available individually, and they have that flap portion sticking out by about 0.5mm. So, by looking at your photo A, you're doing the right thing by manually trimming that flap and if you cannot cut it so closely, then folding in any remainder so that it's not contributing to the width of the terminal any more than 0.5-1mm max overall. In my photo in my other comment, you can see that the flaps are just slightly wider than the rest of the crimp terminal (measured even after crimping to be about 3.6 mm according to my calipers) and it slid in fine into the housing, and I heard the click when it locked.
    It looks like your photo A crimp should easily fully slide into the housing, and lock itself in permanently using the two side wings. If it comes back out, then examining the wings should reveal if the metal is buckling or not.
    There's a chance the Amazon crimps or housings are not genuine Molex (there's plenty of clones of electronic parts and connectors on Amazon and eBay) and might not be made to the same tolerances or of the same materials as genuine Molex.
    (By the way, you seem to have done a fine job with the crimp tool, just a small point is that the bare conductor length should be slightly longer than shown in the photo A, so that it's slightly visible egressing from the crimped portion, and also the wire insulation should be slightly visible from beyond the wire grip portion of the crimp terminal. But that's unrelated to the issue you're experiencing, it was just a minor comment).
