Ask an Expert Forum PT100
  • Answers 3 answers
  • Subscribers 323 subscribers
  • Views 1472 views
  • celex
See a helpful answer?
PT100
celex
celex over 4 years ago
I would like to know with which temperature tester (brand and model) I can use the PT100 probe of TE Connectivity with manufacturer code NB-PTCO-158.
  • geralds
    geralds over 4 years ago +2 suggested
    Hi celex , You can not connect directly that sensor on an temp. tester, if it has not an amplifier. http://www.farnell.com/datasheets/2305684.pdf Please read the data sheet and build a signal conditioning…
  • ajcc
    ajcc over 4 years ago +2 suggested
    It's hard to tell what your idea of a temperature tester is from your question and the product you've picked out (which as far as I can tell is just the cheapest PT100 RTD available on Newark). From your…
  • Gough Lui
    Gough Lui over 4 years ago +2 suggested
    You could test the probe with a handheld indicator that supports Pt100 (but check the alpha value) - some examples include: https://au.omega.com/pptst/HH370.html https://www.tcaus.com.au/temperature_instruments…
  • geralds
    0 geralds over 4 years ago
    Hi celex ,
    Please read the data sheet and build a signal conditioning module with preamp.
    https://de.farnell.com/en-DE/c/automation-process-control/signal-conditioning/signal-converters?signal-conditioner-input…
    Best Regards
    Gerald
  • ajcc
    0 ajcc over 4 years ago
    It's hard to tell what your idea of a temperature tester is from your question and the product you've picked out (which as far as I can tell is just the cheapest PT100 RTD available on Newark). From your question it sounds like you want a handheld meter, but from the sensor it seems like you just want to play around with RTDs? If you search for PT100 Resistance Table you'll notice that you need a fairly accurate way of measuring the resistance, in practice that means a good current source and a differential/instrumentation amplifier.
    If you're familiar with microcontrollers then a development board for something like the MAXIM MAX31865MAXIM MAX31865 all-in-one solution with its SPI interface could be interesting? You can also find a lot of application notes on how to use and build circuits for reading RTDs, like this one from Ti or this blog post from Ti listing different circuit topologies.
  • Gough Lui
    0 Gough Lui over 4 years ago
    • https://au.omega.com/pptst/HH370.html
    • https://www.tcaus.com.au/temperature_instruments/RTD_indicator.html
    or alternatively, if you're near a bench, you could use a high-accuracy DMM and convert resistance values using the standard Pt100 curve.
    Do your own research before making any purchases as I can't guarantee compatibility.
    - Gough
