Ask an Expert Forum led driver circuit
  • Replies 27 replies
  • Subscribers 320 subscribers
  • Views 4327 views
  • led
See a helpful answer?
led driver circuit
terrenone
terrenone over 11 years ago
I need some help with a circuit I need to drive 10 white leds from a 3.7v 2200mAh lipo battery it sounds simple but it has to be able to fit in a small container aproximity 1inch square and not produce a lot of heat,  its for my son's night im making.
Any help is welcome
Dave
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    In this case I would be tempted to replace the 10 LEDs with a single 1 or 3W LED, it will fit easier and can be driven from the 3.7V LIPO with a simple constant current generator with minimal power loss…
    jw0752 over 11 years ago in reply to terrenone +1
    That sounds good Dave. The battery and charging question is resolved. Let me know how your testing of the 5mm LEDs go on the 3.7Volt source. Since you are going to be dealing with relatively low mA I do…
    jw0752 over 11 years ago in reply to Robert Peter Oakes +1
    Hi Peter - Whenever I try to answer one of these questions I am always pleased when one of the fellows, like yourself, with more knowledge and experience add their insight. I have come back to your recommendation…
    0 jw0752 over 11 years ago
    Hi Dave,
    It is good to hear from you. Sorry about the job. Many times the seemingly bad things, like loosing a job, turn out to be what forces you to try new things and opens doors for improvement in your life. Good luck on the new career.
  • D_Hersey
    0 D_Hersey over 11 years ago
    The problem in driving LEDs is that they don't have the linear I/V that resistors do:  Let's imagine a one-volt potential driving a one Ohm resistor or one Siemens conductor.  Current is an ampere and power dissipation is one watt.  Double the potential, Current is two amperes and power dissipation is four watts.  If we double the potential across a diode, current increases by about a factor of ten.  This rules out voltage control and necessitates current control.  The chopper mentioned by a prior poster is the way to go because it is the alternative to simply putting a ballast resistor in series, which often draws more power than the LED.  Indicator LEDs are fine with just the ballast resistor, otherwise, 'get to the choppah.'
    MK is correct (there I said it!) in observing that the canonical op-amp/sense resistor/transistor CCS has stability (and outright slowness) issues  It has been found that a unity-gain buffer in the feedback path makes life much better for this circuit.  Using it in this application makes the power Q get hot rather than the ballast resistor, for what that is worth.  Chopping with a current integrator makes for a situation in which most of the power actually goes into the LED.
    0 Robert Peter Oakes over 11 years ago in reply to jw0752
    Just noticed something John
    The diagram on your text book and my diagrams on the PSU project pages are fundamentally the same, I have not included the OP feedback circuit yet, that's for a bit later in the tutorials but the driver I'm showing (Up to 10A vs  20mA for an LED)
    Power Stages - The Modular Bench Power Supply ++
    0 jw0752 over 11 years ago in reply to D_Hersey
    Thanks Don, I always learn from your explanations. As soon as I started testing I could see that the LED wasn't acting like a resistive load. I will look into the Chopping current regulator. This wasn't my thread but I seem to have hijacked it.
    0 jw0752 over 11 years ago in reply to Robert Peter Oakes
    Hi Peter, It just goes to show that great minds think alike. I am following your PSU tutorial with interest.
  • terrenone
    0 terrenone over 10 years ago
    Hi guys bit of an update for you the first year went realy well it seems like i have a nack for electronics lol thanks angain for the all the help with my project i'll post some pics of it complited when i get chance. well got to go reports to right lol
    thanks guys
    Dave
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to terrenone
    Hi terrenone
    Thanks for the update. Looking forward to seeing the result. image
