Ask an Expert Forum Need suggestions for a good soldering iron
  • Replies 19 replies
  • Subscribers 316 subscribers
  • Views 5437 views
  • pcb soldering
  • soldering tips
  • soldering
See a helpful answer?
rsjawale24
rsjawale24 over 4 years ago
I'm looking to buy a good soldering iron preferably with a fine needle tip that can last long. Power - 25W-35 W
I checked online and there are two types of irons available - Ceramic heater and coil heater type.
I use this one from Soldron (A popular brand in India) but the tips don't last longer esp. if you keep the iron on for longer times. The entire soldering bit starts to give off flakes (some kind of coating comes off).
The only plus point is that the tips are easy to replace and not very expensive.
I found another one from Stanley the tip is tightened using a screw on the side. Probably uses a different heating element too as compared to the above one.
Please suggest good soldering irons to buy (brand, models, etc) which can last longer with power rating of 25W to 35 W. Also, which heating element is better? Coil type or ceramic type?
  • javagoza
    javagoza over 4 years ago +6
    I am not an expert in soldering irons but what I have noticed over the years is that the tips are very damaged if you do not have temperature regulation and some function for the soldering iron to detect…
    shabaz over 4 years ago +4
    Hi Rushiraj, I think both could be ok for general through-hole work if nothing else is available, but both look pretty bad for surface-mount. This is just from general experience from similar-looking tools…
    shabaz over 4 years ago in reply to rsjawale24 +3
    Hi Rushiraj, There's a Multicomp soldering station but is just slightly higher than your budget (it is ~ 100 USD). Personally with $70 budget, I think I would try to buy a used soldering station, but that…
  • kmikemoo
    kmikemoo over 4 years ago in reply to rsjawale24
    rsjawale24  Good choice on your soldering station.  It took me years to finally upgrade from the standard pencil and I am so happy that I did.  You will be thrilled as well.  Happy soldering!
  • rsjawale24
    rsjawale24 over 4 years ago in reply to kmikemoo
    Thanks! Looking forward to use the station and experience the difference between the pencil and station!!
  • hugohu
    hugohu over 4 years ago in reply to Jan Cumps
    They are electroplated, certainly. I didn't tin the tips that came originally correctly, but my official replacement tips failed to tin with any solder i had, yet it was easily tinned with the 900m-t tips(from PCBway bazaar, one that came with atten, and a mechanic tip) with my cheapest solder, as well as the "better" ones.
  • jameslandry
    jameslandry over 4 years ago
    The Plusivo 60W Soldering Iron is a good soldering iron. I like the extra shrink tubing, which I often use in circuitry projects. The included pen screwdriver with a set of seven magnetic bits is handy for disassembling and accessing circuit boards. Moreover, the storage bag has a convenient and durable design that is easy to pack and carry around.
    • Vote Up -1 Vote Down
    Jan Cumps over 4 years ago in reply to jameslandry
    Great website (if you want to learn how not to hold an iron), warm fingers
  • colporteur
    colporteur over 4 years ago
    I would encourage you to check out the following soldering stations RoadTest reviews.
    METCAL GT120-HP-T6 Soldering Station
    Weller Soldering Station WT Series
    I think it can provide you with some useful information in making a purchase decision.
    To avoid self-promotion use the links provided and you can examine each review using the Recent Reviews links on the right-hand side.
  • daviddarwin
    daviddarwin over 3 years ago
    The Plusivo 60W Soldering Iron is a value-for-money electronics soldering package. I like the extra shrink tubing, which I often use in circuitry projects.
    shabaz over 3 years ago in reply to daviddarwin
    Spammy, posting an identical comment to a previous one by supposedly someone else.
    Anyway, it's junk... Avoid this, and get a proper iron. The Plusivo one is not earthed, see photo below.:
    shabaz over 3 years ago in reply to jameslandry
    I like how on that review website, all the top 5 soldering irons are identical Joy Except one is pink.
    All junk, no earth connection.
