Ask an Expert Forum Miller DX200 welder SEMIKRON SkiiP 33NEC125T2 Power IGBT Module
  • Replies 97 replies
  • Subscribers 343 subscribers
  • Views 24066 views
See a helpful answer?
mb443
mb443 over 4 years ago
imageThe hot topic for those who owns DX200 welder and willing to participate in re-implementing of the original PowerModule on discrete elements.
This is continuation of the discussion and efforts already put into at other forum:  Miller Boost Circuit Board Assembly NO. 200841
This is a restoration project attempt of reproducing using discreet components an obsolete  power module  which SkiiP 33NEC125T2 no longer produced by SEMIKRON.
DISCLAIMER: This is a high voltage project DANGER. Anyone who joins this experimental project need to be aware of high voltage (up to 1000v) and high currents (up to 100A) which is a high risk and requires to be qualified to work with such circuits and can be done only at your own risk.
  • lanuser
    lanuser over 4 years ago in reply to mb443 +1
    I am no longer interested working on this project. Seems to me besides two people nobody else step forward. I have specially missed one pin on Schematic design, after I ask you to double check my work…
  • alvideo
    alvideo over 4 years ago in reply to alvideo +1
    I redraw module inside wiring like original, exept i added for all IGBT gate resistors. In wiring connectors names are like in module picture (see below). ` Here some more wiring outside…
  • Ubbi.wan
    Ubbi.wan over 3 years ago in reply to lanuser
    Good morning lanuser!
    Sure!
    R1 - 330Ω (332Ω 2%) // R2 - 329.5Ω (332Ω 2%) // R10 - 329.3Ω (332Ω 2%) // R13 - 330.6Ω (332Ω 2%) // R14 - 329 (332Ω 2%) // R15 - 329.5 (332Ω 2%)
    D2 - 0.742 (18V/1W modified/ burned once) // D3 - 0.739 (18V/1W modified/ burned once) // D8 - 0.661 (2x parallel18V/0.5W modified/ burned once) // D9 - 0.676 (2x parallel18V/0.5W modified/ burned once)
    Q9 - 0.691-EB 0.665-CB (2N3906 PNP)  //  Q10 - 0.693-BE 0.673-BC (2N3904 NPN)  //  Q16 - 0.695-BE 0.676-BC (2N3904 NPN)
  • lanuser
    lanuser over 3 years ago in reply to Ubbi.wan
    IRFD110: Q8, Q4, Q7, Q12, Q14, Q18, Q20, Q24, Q25, Q28
    IRFD9120: Q3, Q5, Q6, Q11, Q13, Q17, Q19, Q23, Q26, Q27
    2N3904: Q2, Q10, Q16, Q22, Q29, Q30, Q31
    2N3906: Q1, Q9, Q15
    Checked from none modified working board.
  • lanuser
    Did you checked resistor values with a multimeter or just labels on the resistors?
  • Ubbi.wan
    Thank you soo much @lanuser!
    I'll purshase some components that burned and put then in correct order now.
  • Ubbi.wan
    Multimeter and label. Multimeter is the value after ID resistor and label in parentheses.
  • lanuser
    Make sure before powering up the unit... place 200W Lightbulb  to avoid component damage.
    If lightbulb is bright and not going to dim.... use flir thermal camera or any thermal camera to see what components are getting hot.
    Be carful because on the Mail Power Board there is  HIGH voltage. 900V
    e14 Contributor over 3 years ago in reply to mb443
    [deleted]
