Ask an Expert Forum Miller DX200 welder SEMIKRON SkiiP 33NEC125T2 Power IGBT Module
  • Replies 97 replies
  • Subscribers 343 subscribers
  • Views 24044 views
See a helpful answer?
mb443
mb443 over 4 years ago
imageThe hot topic for those who owns DX200 welder and willing to participate in re-implementing of the original PowerModule on discrete elements.
This is continuation of the discussion and efforts already put into at other forum:  Miller Boost Circuit Board Assembly NO. 200841
This is a restoration project attempt of reproducing using discreet components an obsolete  power module  which SkiiP 33NEC125T2 no longer produced by SEMIKRON.
DISCLAIMER: This is a high voltage project DANGER. Anyone who joins this experimental project need to be aware of high voltage (up to 1000v) and high currents (up to 100A) which is a high risk and requires to be qualified to work with such circuits and can be done only at your own risk.
  • lanuser
    lanuser over 4 years ago in reply to mb443 +1
    I am no longer interested working on this project. Seems to me besides two people nobody else step forward. I have specially missed one pin on Schematic design, after I ask you to double check my work…
  • alvideo
    alvideo over 4 years ago in reply to alvideo +1
    I redraw module inside wiring like original, exept i added for all IGBT gate resistors. In wiring connectors names are like in module picture (see below). ` Here some more wiring outside…
  • lanuser
    I have specially missed one pin on Schematic design, after I ask you to double check my work, your reply seems OK.
    Therefore, in conclusion --->  working on this project is a waste of time.
    I am moving My work to my own private website.
  • A3JBNE
    A3JBNE over 4 years ago in reply to lanuser
    I still do not dare to carry out that project, I would opt for the option of designing a second PCB for mounting commercial transistors
  • alvideo
    alvideo over 4 years ago in reply to lanuser
    What is Your site?
  • lanuser
    lanuser over 4 years ago in reply to alvideo
    I stopped working on this project.
    Website: www.369support.com/1/
    However,  Site is closed to public... personal/internal  use only.
    If you need help let me know.
    Thank you.
  • serg200010
    serg200010 over 4 years ago in reply to lanuser
    Hello, I am interested with your project,  how i can register at your website?
  • alvideo
    i have Miller DX200 powermodule main points waveforms (oscillograms). Maybe it change Your mind to continue this project?
  • serg200010
    serg200010 over 4 years ago in reply to alvideo
    it will be Great! you you mind to share waveforms?  Thank you!
  • mb443
    mb443 over 4 years ago in reply to alvideo
    Hi alvideo, welcome back! I figured you'll continue with this. That's great! Did you actually succeed w/ testing? See if you want to drop interesting materials here, may really help others. Seems the army of dead units owners growing...
  • lanuser
    lanuser over 4 years ago in reply to serg200010
    Sorry my site for my personal use only.
    If you would like we can continue to work on this project here in this forum / board.
    However, I would like to see other members step into this project and share their finds and test results.
    If someone is interested I can repost Power Module images of reverse engineered info with "mb443" and i.
  • lanuser
    lanuser over 4 years ago in reply to lanuser
