Ask an Expert Forum Automatic Wire Cutter With Timer
  • Replies 8 replies
  • Subscribers 302 subscribers
  • Views 2176 views
  • cutter
  • wire
See a helpful answer?
Jhon_Davis
Jhon_Davis over 3 years ago
Hi dear pro creators,
Please check this out :
https://www.youtube.com/watch?v=WVnbbqSEDU0
I want an "Automatic Wire Cutter With Timer" very very tiny.
What is my mean tiny?
Imagine there is a Network cable on the wall.
I want set this machine around that cable and set timer for tomorrow.
Tomorrow at the exact time i want cut that wire auto.
The mechanic should have low site to put around the wire on the wall.
Is it possible to create such this machine?
My desire size is like a little camera.
Please advice me with what equipments i can create such this machanic?
  • beacon_dave
    beacon_dave over 3 years ago +1
    Difficult for people to advise without either an example use case or a more detailed specification. However, given that you can already get handheld cordless cable cutters which can repeatedly slice…
  • Jhon_Davis
    0 Jhon_Davis over 3 years ago
    No body here for even one answer?
    • Vote Up -1 Vote Down
    0 shabaz over 3 years ago in reply to Jhon_Davis
    I read it and didn't initially reply, because it doesn't seem to have a legitimate purpose, apart from perhaps annoying someone or doing something malicious.
    You chose not to provide a use-case, so I chose to interpret it this way.
  • Jhon_Davis
    There is no malicious purpose on this request.
    People are interested on this little machine in my area.
    So what is your excuse?
    Just tell is it possible to create such this device or not?
  • beacon_dave
    0 beacon_dave over 3 years ago
    However, given that you can already get handheld cordless cable cutters which can repeatedly slice through large diameter cables, I would expect it would be possible to scale down substantially in order just to do a single cut through a single small diameter network cable.
    There are other ways to reduce the size significantly but once again depends on use case.
    Complying with local safety regulations might be more of an issue when bypassing safety mechanisms with automated timers and operating autonomously.
  • Jhon_Davis
    Here is the usage :
    I want to put this device around a network cable and leave it for 1 day.
    After 1 day it should cut that cable auto.
    Device should be in the smallest possible size.
    What will happen about that cable or what is the purpose of this mission? This is not our business.
    We just create machines and sell them on the market..
    What will happen about the cutter after cut?
    It can stick on one side of cable.
    "What will happen about that cable or what is the purpose of this mission? This is not our business."
    That's pretty irresponsible. Maybe you should consider the potential consequences, and take some responsibility?
  • Jhon_Davis
    "That's pretty irresponsible. Maybe you should consider the potential consequences, and take some responsibility?"
    Why do you bother yourself about it?
    The responsibility is on cutter man, Not me as reseller or you as creator.
    Is creator of knife responsible on any killing on the street?
    Of course not.
    So put your mind on the creation - Not else.
  • Jhon_Davis
    Just tell me what tools are needed for this job?
    I will create it by myself.
