Ask an Expert Forum How control many servos?
  • Subscribers 302 subscribers
  • Views 1718 views
  • learning circuit
  • electronics
  • beginner
See a helpful answer?
Geek-Zard93
Geek-Zard93 over 3 years ago
I have an Idea inspired in the kinetic sculptures and the art installation Reflection made by Adam Cigler, Petr Vacek and Prusalab, my idea is like a clock using many hexagonal mirrors where each hexagonal is pull out by a servo so I would like know the different ways to control many servomotors, as brain I've though to use an ESP32, how should I start I would like to design my own board that brings all elements necessary to this project, could you suggest me how to create a properly PCB?.
Concept Idea
"Reflection" - Making of an art installation for Prague Signal Festival
Thank you for your comments!!.
    dougw over 3 years ago +4
    Adafruit 16-Channel 12-bit PWM/Servo Driver Adafruit 16-Channel 12-bit PWM/Servo Driver
  • beacon_dave
    beacon_dave over 3 years ago +2
    Enrico's 'dynamic surface' project here on the Element 14 forum may also be of interest: /challenges-projects/design-challenges/pi-iot/b/blog/posts/piiot---the-perfect-reading-place-19-tech-dynamic-surface…
    michaelkellett over 3 years ago in reply to dougw +1
    Hi Doug, Your link doesn't work (at least in UK), this is what I got: Sorry, we couldn't find the page you were looking for Did you type the web address? Please be sure to check your spelling…
    Hi Doug,
    Did you type the web address? Please be sure to check your spelling.
    Did you follow a link? That page may have been moved or deleted. Let us know about the problem.
    You Could Try...
  • cstanton
    cstanton over 3 years ago in reply to michaelkellett
    The product link is to the american store, which won't work for UK because there's no equivalent UK product code.
    It was to this:
    https://www.newark.com/adafruit/815/silicon-manufacturer/dp/42X3730
    Which isn't stocked at Farnell UK, but there're products that use the chip:
    https://uk.farnell.com/search?st=pca%209685
  • beacon_dave
    /challenges-projects/design-challenges/pi-iot/b/blog/posts/piiot---the-perfect-reading-place-19-tech-dynamic-surface-design-and-simulation
    /challenges-projects/design-challenges/pi-iot/b/blog/posts/piiot---the-perfect-reading-place-20-tech-dynamic-surface-making-the-m-pix-prototype
    /members-area/top-members/f/forum/7030/super-almost-crap-preview
    as might the Morph project:
    https://vimeo.com/347446497
  • fmilburn
    fmilburn over 3 years ago in reply to michaelkellett
    It worked for me in the US but I get the same thing sometimes when people link Farnell.   I've tried using the product code for Newark and the E14 insert product link function below:
    Adafruit Servo Driver
    It can also be seen at the Adafruit site.
    dougw over 3 years ago in reply to cstanton
    When I try to order a part that is not in stock at Newark, it seems to do a good job of finding it at Farnell or Avnet, so somewhere the product codes seem to have links.
