Ask an Expert Forum Using TVS Diode P6KE across relay coil but then also relay coil is getting damaged.
  • Replies 21 replies
  • Subscribers 340 subscribers
  • Views 4612 views
See a helpful answer?
We are using TVS diode across 24V DC-100AMPs relay for automotive application but my relay coil is getting damaged.
    mcb1 over 10 years ago in reply to e14 Contributor +1
    Unfortunately the schematic shows a relay and not what is connected on the load side, or how the 24v DC is sourced (ie switchmode supply, battery, etc). What is on the end of the 100A contacts.? ie a simple…
    That image helps.... There is no heating apparent from the contact as it seems to be a nice copper colour. The coil wire appears to have fused. For any inductive circuit the In-rush/ON current is very…
    We are trying to help.... If you can't provide a circuit then I'm afraid my anwers are limited to guessing ... Mark
    e14 Contributor over 10 years ago in reply to jw0752
    Thank You ,we just reduced the diode breakdown current.
