Ask an Expert Forum Need help to replace a resistor
  • Replies 27 replies
  • Subscribers 334 subscribers
  • Views 10282 views
See a helpful answer?
ldarby
ldarby over 3 years ago
Hopefully this isn't a dumb question but this resistor is cracked and slightly burnt.  I measured it, it's open circuit.   It's from my bosch washing machine which is about 12 years old.  I think it's brown, black, silver, gold which is 0.1 Ohm (can't be grey, that's 1 giga ohm), but I've found several other photos showing this resistor on this pcb is brown black brown, 100 ohm, and people saying it's 100 ohm as well, and no one saying it's 0.1 ohm.  It's 'Ako 731799-06 BSH 9000449412'  if you would like search yourself.  Could it really be 100 ohm, and the burn slowly chared ring 3 to look grey/silver over time?  If it's supposed to be 100 ohm, and I replace it with 0.1, I'm sure it'll blow up...
Next question, since this failure seems to be very common, would it make sense to replace it with a higher power resistor e.g. 5W or 10W?
Thanks.
    shabaz over 3 years ago in reply to ldarby +4
    Unfortunately not enough detail from the photos, the connection snakes off from the top side of the board, but I can't see where due to angle. Anyway, it's a resistor directly off the Live connection…
  • ldarby
    ldarby over 3 years ago in reply to anniel747 +2
    Yeah, oops, maybe was possible. There was a much larger crack (not shown in above photos), I tried opening up that crack but that made the whole shell pop off and took all the wire with it... lesson l…
  • ldarby
    ldarby over 3 years ago in reply to shabaz +2
    Thanks very much for that, the chip left of center is a full bridge rectifier, it connects to that, then the cap is 10uF, 400V, and that connects to the D (Drain) pin. I couldn't see any inductors though…
  • anniel747
    anniel747 over 3 years ago in reply to ldarby
    [deleted]
  • ldarby
    Yeah, oops, maybe was possible.  There was a much larger crack (not shown in above photos), I tried opening up that crack but that made the whole shell pop off and took all the wire with it... lesson learnedimage
    Anyway, it's a resistor directly off the Live connection, it is highly unlikely to be 0.1 ohm. Since you mention the LNK chip might have failed, then there's a good chance it is related, since the LNK circuit uses a fusible resistor connected to Live.
    See here (from LNK design guide PDF):
    There's a high chance it could have been 100 ohm, or 10 ohm, but certainly not 0.1 ohm.
    You could check with a multimeter on the _unpowered_ board with _capacitors_discharged_first_ that the trace from the resistor goes to a diode and onward to an inductor and then to the LNK chip as shown in the LNK datasheet PDF:
    If so, then you know that resistor has to be 100 ohm or 10 ohm. You could just try 100 ohm, and see if it works If it doesn't, then try 10 ohm.
    I couldn't find a 100 ohm fusible resistor but if it is being used in that topology you could use a 68 ohm resistor, but don't blame me if it all goes up in flames or worse - I'm not providing advice here.
    Here is a 10 ohm fusible resistor:
  • ldarby
    Thanks very much for that, the chip left of center is a full bridge rectifier, it connects to that, then the cap is 10uF, 400V, and that connects to the D (Drain) pin.  I couldn't see any inductors though apart from the large one near the mains.
    And that  design guide confirms it's used as a fuse, so will get a 100R 2W flame proof one (and not a 10W one...).  (I'm sure it was 100R based on measuring the bits of wire, see below).
  • Gandh1
    Gandh1 over 2 years ago in reply to shabaz
    Hi shabaz and ldarby would you be able to assist me with identifying the right resistor for my bosch dishwasher. Im actually an appliance engineer, and come across several of these burnt out and now its happened to mine, i wanna have a crack at fixing it if possible.
    Its very similar to ldarbys one, in terms of dimensions, but slightly different resistance due to different coloured rings. Gold, pink black/dk grey, brownimage
  • anniel747
    anniel747 over 2 years ago in reply to Gandh1
    [deleted]
  • Gandh1
    Gandh1 over 2 years ago in reply to anniel747
    Yes i realised that wrong way round after posting but not had chance to edit it.
    So by my limited electronic knowledge its probable heatfading causing purple to look pink... So:
    Brown black purple gold making it
    10,000,0000 ohms with a 5% tolerance?
    But thats about as far as i can get.
    Appreciate any and all help
    Ps its 220-240v british appliance, not sure of input voltage or current it's taking
    shabaz over 2 years ago in reply to Gandh1
    It's likely a very different value than that. The colours fade in the heat, so it is not so easy to guess what the value was from that. As anniel747 mentions, you should try to measure it with a multimeter set to ohms (with everything off of course).
    It might not be faulty, it is normal for them to change colour during years of operation. Although there is more discoloration on one side, so it's hard to tell if it is faulty or not. A measurement is needed to see if it can approximately match some of the colors.
  • Gandh1
    Its definitely faulty, dishwasher was on yday then at the end of cycle during hot rinse (when machines drawing maximum current load) there was a pop and electrics tripped. Knowing these machines i went straight to pcb and there was a little electronic burning smell and the resistor casing is cracked and burn marks, sorry wasnt visible in photo as its the one i used for google lens that brought me here.
    Its also o/c so cant measure it
    I see.. in that case, it could be worth a shot trying 100 ohm (needs to be a flameproof, fusible resistor). The LNK304 datasheet shows a 8.2 ohm resistor, i.e. there's a chance it could be 10 ohm, with the band being black rather than burnt-brown color, but from the colors alone, 100 ohm looks more likely, and would be worth giving 100 ohm a try first.
