Ask an Expert Forum Need help to replace a resistor
  • Replies 27 replies
  • Subscribers 334 subscribers
  • Views 10283 views
See a helpful answer?
ldarby
ldarby over 3 years ago
Hopefully this isn't a dumb question but this resistor is cracked and slightly burnt.  I measured it, it's open circuit.   It's from my bosch washing machine which is about 12 years old.  I think it's brown, black, silver, gold which is 0.1 Ohm (can't be grey, that's 1 giga ohm), but I've found several other photos showing this resistor on this pcb is brown black brown, 100 ohm, and people saying it's 100 ohm as well, and no one saying it's 0.1 ohm.  It's 'Ako 731799-06 BSH 9000449412'  if you would like search yourself.  Could it really be 100 ohm, and the burn slowly chared ring 3 to look grey/silver over time?  If it's supposed to be 100 ohm, and I replace it with 0.1, I'm sure it'll blow up...
Next question, since this failure seems to be very common, would it make sense to replace it with a higher power resistor e.g. 5W or 10W?
Thanks.
    shabaz over 3 years ago in reply to ldarby +4
    Unfortunately not enough detail from the photos, the connection snakes off from the top side of the board, but I can't see where due to angle. Anyway, it's a resistor directly off the Live connection…
  • ldarby
    ldarby over 3 years ago in reply to anniel747 +2
    Yeah, oops, maybe was possible. There was a much larger crack (not shown in above photos), I tried opening up that crack but that made the whole shell pop off and took all the wire with it... lesson l…
  • ldarby
    ldarby over 3 years ago in reply to shabaz +2
    Thanks very much for that, the chip left of center is a full bridge rectifier, it connects to that, then the cap is 10uF, 400V, and that connects to the D (Drain) pin. I couldn't see any inductors though…
  • Gandh1
    Gandh1 over 2 years ago in reply to shabaz
    Ok what ill do is desolder it then take a photo from the opposite side to the crack and post it here.
    Considering the bands are different colours to OP, would that not mean it would be a different value to OPs?
    shabaz over 2 years ago in reply to Gandh1
    Your bands look Brown Black Brown Gold, or (perhaps) Brown Grey Brown, which would make it 100 ohm, or 180 ohm. 100 ohm is more likely from the colors I reckon. And if that third band experienced more heat, then I'm speculating it may be a black band, i.e. 10 ohm or 18 ohm.
    Probably 100 ohm is most likely, but there's a chance it could be 10 ohm. I don't think more of the board will be damaged if you attempt with a 100 ohm fusible flameproof resistor but no guarantee there's no other fault of course.
  • Gandh1
    Im happy to have a go at a £15 repair as a new board is £200 sonits a write off. The 3rd band is definitely a different colour to black and brown bands. As i said if pink isnt a colour then its definitely purple
    It definitely can't be purple (if it was, you'd need thousands of volts across it to even begin to get hot enough to discolor). That band has just experienced a hotter temperature to the other bands. It's most likely a brown band, or if not, possibly black.
  • Gandh1
    Ive just been thinking i think i have a similar machine in storage for parts where the pcb is good. Its not compatible but it might have the same resistor on it. Ill measurebthst and post a photo of it
  • anniel747
    anniel747 over 2 years ago in reply to Gandh1
    [deleted]
  • Gandh1
    Gandh1 over 2 years ago in reply to anniel747
    Unfortunately the BOM only covers the parts selections not actual design specifications. Even if i was employed by bosch, (one of my predecessors is now a lead engineer for them) i would still only have access to part number lists (i know this as I tapped him up yesterday).
