Ask an Expert Forum How to control the HV converter with analog voltage signal?
  • Replies 28 replies
  • Subscribers 334 subscribers
  • Views 5272 views
  • power_electronics
See a helpful answer?
Dykan
Dykan over 3 years ago
The HV converter require 24V power supply and some analog voltage signals. I connect two 0~10V voltage signals to the pin of HV converter, 10HVA24-N1. However what I get from the output of HVA is 0V. Is there any thing wrong with my wiring?
  • jc2048
    jc2048 over 3 years ago in reply to Dykan +3
    Pin 12 is the current monitor output. It will output a voltage that's proportional to the HV current being supplied by the module. Hopefully there's enough resistance in series with the output that you…
    michaelkellett over 3 years ago in reply to Dykan +2
    So it looks as if your power supply thinks it is working. How is you divider working - (diagram) - its a strange co-incidence that 100uA into 0.63M would give excatly 63V. Your power supply max output…
  • dang74
    dang74 over 3 years ago +1
    Interesting device. Reading through the app note that is available on the manufacturer's website I noticed that pin 11 can be driven by TTL. The app note suggests that the level on pin 11 must be at least…
  • dang74
    0 dang74 over 3 years ago
    Interesting device.  Reading through the app note that is available on the manufacturer's website I noticed that pin 11 can be driven by TTL.  The app note suggests that the level on pin 11 must be at least +2.4V to enable the converter.  Are you satisfying this condition?
    0 shabaz over 3 years ago
    As dang74 says. it may be related to pin 11. A couple of resistors could help provide the right input to that pin. The resistors below will provide about +4V to the enable pin, which is within its supported range. You should be checking with a multimeter.
  • Dykan
    0 Dykan over 3 years ago
    dang74 ,shabaz
    Thank you for reply. I provide the pin11 and the pin6 with 10V for enable or 0V for disable, while pin2 and pin6 with a step voltage between 0 and 10V.
    Don't worry, the TTL can afford 10V.
  • charlieo21
    0 charlieo21 over 3 years ago
    The connections look fine, can you test with a different unit? maybe is damaged.
  • jc2048
    0 jc2048 over 3 years ago in reply to Dykan
    What are you doing with the current-limit programming (pin 13)? If that input is arranged like the voltage programming, it will default to zero without anything driving it.
  • Dykan
    0 Dykan over 3 years ago in reply to charlieo21
    I have tested another same model HV converter, but likewise.
  • Dykan
    0 Dykan over 3 years ago in reply to jc2048
    I just finish a test today, and the pin12 voltage is controlled with an additional 10V AO, but the HVA output is 0V. Interestingly, when my AO is connected to pin12, even though I program the AO to be 10V, the actual measurement shows 0V. And once I remove pin12, my AO can be detected as 10V again.
  • jc2048
    Pin 12 is the current monitor output. It will output a voltage that's proportional to the HV current being supplied by the module. Hopefully there's enough resistance in series with the output that you haven't damaged it by back-driving it with a voltage.
    The programmable current limit input is pin 13.
  • anniel747
    0 anniel747 over 3 years ago
    Pin 15?
  • Dykan
    0 Dykan over 3 years ago in reply to anniel747
    Pin15 is the same as pin 6
