Ask an Expert Forum cga to vga converter uPython
  • Replies 46 replies
  • Subscribers 332 subscribers
  • Views 8573 views
  • python
  • raspberry pico
  • ask_an_expert
  • microcontrollers
  • teensy
  • vga
See a helpful answer?
rlaci
rlaci over 2 years ago
Hi
im new to uPython and needing some help with fast interrupts, port handling, reading into controller, handling the big amount of data and speed
my main aim is to get it working on raspberry pico, as colors 1bit resolution is enought as its an industrial equiment with RGBHV 15.6khz input(output from the machine) need to transfer it to 31khz VGA standard output for an lcd monitor
any help welcome
thanks!
    shabaz over 2 years ago +3
    There's a website listing monitors that support your resolution: http://15khz.wikidot.com/ I think it's far more likely that you'll be able to source a monitor if you search long enough on eBay, than…
  • beacon_dave
    beacon_dave over 2 years ago in reply to shabaz +3
    There is a PIO based implementation of a VGA driver discussed here if anyone is interested: https://www.youtube.com/watch?v=ZXMdZGQzrWg
    michaelkellett over 2 years ago in reply to rlaci +3
    It's very, very difficult. You need to delve quite deeply into the data sheets. The things to look for are the IO toggle rate, maximum clock rate of internal RAM, and maybe some benchmarks of complete…
  • rlaci
    0 rlaci over 2 years ago in reply to beacon_dave
    nice hint as i saw on ebay its common in usa but im from europe
    0 shabaz over 2 years ago in reply to dougw
    Hi Doug,
    He needs to change pixel rate, which requires electronics. I suspect the cable in the photo is unlikely to do that, there's no power source connection in the photo (there may be power delivered through a VGA connector, but I believe it's in the direction from PC->monitor, not monitor->PC).
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to rlaci
    Probably just ignoring the intensity bit in that case.
    Perhaps something more like this then:
    https://www.amazon.co.uk/Mcbazel-Arcade-Converter-Monitor-Projector-Black/dp/B078ZDTLBJ/ref=sr_1_1
    0 shabaz over 2 years ago in reply to beacon_dave
    That looks like it will do the job!
  • rlaci
    0 rlaci over 2 years ago in reply to shabaz
    i saw that cable before and i predict its from vga to rgb not from rgb to vga
    solutions what i found as standalone products:
    - GBS2019 Xvga box but was highly delayed when i first searched it
    - getting a 15khz monitor, i got one and not working possibly the 63Hz vertical sync messes it up
    - Extron VS 304 looks documented like can work, but at the rgbhv place the resolution was not really documented i got this info here from beacon_dave
  • beacon_dave
    It's a bidirectional cable but passive.
    AV installs often ran RGBHV over 5 coax cables whereas PC's used the 15pin Hi Density 'D' type connector with additional I2C DDC data line. Early multisync monitors used to come with the 5x BNC as default as well. These type of cables were common place to convert between the two physical formats.
  • rlaci
    15khz monitor i picked up is not working with this signal, but i was able to visualize with synthetic clock on the HV pins
    - with teensy 3.2 in arduino only 12Mhz and the signal wasnt too symetric. i bet arduino compiller ads some instructions to the code even when you are using asm code
    - with micropython i was able to reach 62MHz freq with PICO and I have a teensy 4.1on my desk if pico isnt enought but i believe it is
    as far as my equipment i have a fluke 124 scopemeter and digital discovery 3 as logic analyzator, generator etc
    do you have experience with upython programming? advice for learning stuff connected with porting and asm code for different controllers? i think im gonna stuck with teensy and pico in the future
  • rlaci
    i saw a DVS 406 unit in europe, is it better or worse newer older equipment?
    i hope it does not mean the signal just passes throught and no processing done for the output signal :D
    • Scales composite video, S-video, component video, and optional SDI inputs with RGBHV pass-through
  • beacon_dave
    Similar unit, just more inputs and has the pass through functionality. Looks like it is optimised for PAL / NTSC video though but that might just be the sales pitch.
    The pass through is an input loop feature that allows you to insert the device into an existing signal path without interrupting it. The scaling happens between the inputs on the left and the outputs on the right.
    I don't think either of these boxes are much use to you if you definitely have the original CGA TTL level signals, unless you were to convert the levels first.
    The board I linked to on Amazon, looks a closer match for your needs, as it looks like it has been designed for the 1980s CGA/EGA TTL level signals. Looks like it is aimed at keeping some of the early video gaming systems alive with modern displays.
  • beacon_dave
    Some more to check out
    https://www.serdashop.com/MCE2VGA
    ( https://github.com/lfantoniosi/mce2vga )
    https://www.serdashop.com/MCE2HDMI
