Ask an Expert Forum POWER FOR SOLENOID VALVE
  • Replies 35 replies
  • Subscribers 331 subscribers
  • Views 6898 views
See a helpful answer?
Afiq
Afiq over 2 years ago
When 36W supply to specification 16W solenoid valve normally open, is there is effect to the solenoid valve?
  • Anthocyanina
    Anthocyanina over 2 years ago in reply to Afiq +5
    your valve works with 230V AC, it will not work (to specification, if at all) with a 24V power supply
    Jan Cumps over 2 years ago in reply to Andrew J +4
    Maybe ordered the wrong one? There is a 24 V version:
    michaelkellett over 2 years ago in reply to shabaz +3
    The article is a bit misleading since it refers to inrush current when it means current when the solenoid armature is extended out of the coil. It may common to describe it this way but it's not that helpful…
  • Afiq
    0 Afiq over 2 years ago in reply to Afiq
    This is the issue regarding valve not trigger to close.
  • Afiq
    Anyone can help advise me to solve this issue?
    0 shabaz over 2 years ago in reply to Afiq
    For this problem, it's best to call in a professional, let them check out your electrical system design, and get someone qualified to install a replacement if needed. It's not even a majorly expensive part, but that alone no longer seems to be the entire issue; you may also have system or design related problems, so it's best to get an expert to check it all out.
    0 Jan Cumps over 2 years ago in reply to Andrew J
  • Afiq
    0 Afiq over 2 years ago in reply to Jan Cumps
    Well noted Jan Cumps . Thank you very much for information.
