Ask an Expert Forum i want to build a circuit that expands dc range
  • Replies 9 replies
  • Subscribers 335 subscribers
  • Views 1631 views
See a helpful answer?
acdc90
acdc90 over 2 years ago
Hello
most of the time i repair stuff. so not used to designing
the input to this circuit min=0.48v max=2.5v
i want to expand the output to min=0 max =2.5v
this is for a anilog input and power supply of 5v
if i needed to generate a negative rail i could just use dc-dc module
as it would only be a 1 off i would just use vero board and DIL ic
    thank for looking
    shabaz over 2 years ago in reply to acdc90 +3
    Unfortunately, this still needs a lot more information. Unless you're fully open about the actual use-case, and provide as much detail as possible about what this is for, it's near-impossible to help.…
    michaelkellett over 2 years ago +1
    There are lots of ways this could be done but none are perfect. You need to tell us what the source of the signal is and where its going. The more you explain the context the better the answer you will…
    0 dougw over 2 years ago
    How much power or current does it need to supply? (at 5V)
    This chip gets down to 0.7 V....
    https://www.ti.com/lit/ds/symlink/tps61098.pdf?ts=1715554368492
    But it is tough to build it on a Vero board.
    0 michaelkellett over 2 years ago
    The more you explain the context the better the answer you will get. The information you have provided so far isn't quite enough to make any good suggestions.
  • acdc90
    0 acdc90 over 2 years ago in reply to michaelkellett
    THE OUTPUT from this is going into a DAQ unit that i don,t have info for so output current would be minimal
    this is feed into a computer program which can do automatic calibration
    but when the calbration is used the input limits drift which will eventually crash the program
    so i set this up using a external pot  and worked for 3 hours no problem before i shut it down
    so i think with dual op amp ic and twin rail i should get to 0v min
    You could try a joule thief circuit.....
    https://www.youtube.com/watch?v=nBn4JEvv93c&ab_channel=HowDoYou%3FDIY
    https://www.youtube.com/watch?v=K53beWYdIpc&ab_channel=bigclivedotcom
  • scottiebabe
    0 scottiebabe over 2 years ago in reply to dougw
    I'm guessing the OP wants to condition a signal with Vo = a + bVin, but not sure...
    0 shabaz over 2 years ago in reply to acdc90
    Unfortunately, this still needs a lot more information. Unless you're fully open about the actual use-case, and provide as much detail as possible about what this is for, it's near-impossible to help. The original information was extremely minimal, this is currently only fractionally better.
    If you really think you need an op-amp circuit then you can plug the values into an online calculator and get a circuit: https://masteringelectronicsdesign.com/differential-amplifier-calculator-2/
    However, whether that will actually provide a real solution or not, I have no idea, because the information isn't there.
  • anniel747
    0 anniel747 over 2 years ago in reply to acdc90
    Why did it stop working correctly?
  • dang74
    0 dang74 over 2 years ago
    The way I interpret your setup is as follows:
    You are using a circuit to calibrate a DAQ instrument.
    Ideally you would like this 'stimulus circuit' to operate from 0V to 2.5V.
    Unfortunately instead of 0V, the stimulus circuit only goes down to 0.48V.
    My comments:
    If your stimulus circuit has an op-amp  ensure that it is a rail to rail type, or look to using a negative rail as you suggest in your later post.
