Ask an Expert Forum UKCA (or CE) marking required for LED ceiling lamps?
  • Replies 34 replies
  • Subscribers 333 subscribers
  • Views 8062 views
See a helpful answer?
Andrew J
Andrew J over 2 years ago
One for the sparkys here in the UK: does an LED ceiling lamp sold in the UK market require a UKCA (or CE) marking?  Any other marking to show regulatory compliance, if necessary?
I ask, because I have received a LED ceiling lamp that has 7 arms with LEDs in a round metal holder at the ends.  It is intended for direct connection to the 240V lighting circuit with the full voltage going to each metal holder at the end of the arms (no earthing point in those metal holders.)
The ceiling rose is also metal, has no earthing point, has 30AWG (or close) out to the LED holders intended to be connected to supplied (but not fitted) slightly thicker wires which then need to be connected to the lighting circuit.  Frankly, it looks dangerous to me and I'm not installing it; really I ought to have known better but there you go, impulse purchase.
I'm going to push for money back and wanted to know if a lack of regulatory marking was something I could add to the evidence.
    Jan Cumps over 2 years ago in reply to Andrew J +4
    Offer it to the altar of the god of unsafe UK appliances: https://www.bigclive.com/
    Jan Cumps over 2 years ago +2
    Not going to comment on UK standards, but on the safety and grounding expectations: Does it have this symbol for double isolation on it? That would define that it's supposed to be wired without ground…
  • Andrew J
    Andrew J over 2 years ago in reply to Jan Cumps +2
    If they don't send me a return label perhaps I will
    0 Jan Cumps over 2 years ago in reply to Andrew J
    looks like a typical circuit:
    live voltage -> rectifier, smoothing capacitor with bleeding resistor -> LED driver with current sense/set resistor.
    I bet that the wire is sufficient for the low current that this takes: +- 12W at 240V is way below 100 mA
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to Jan Cumps
    The issue perhaps is when you connect it to a lighting circuit and your fault current exceeds that wire gauge in the light fitting. If there is no fuse between the fitting and the circuit, then you end up with a fire starter.
    0 Jan Cumps over 2 years ago in reply to beacon_dave
    In Europe, it's very rare  to have a fuse there. Same with appliances and utility plugs: fused at the fuse box,
    I know it's different in UK installations.
  • beacon_dave
    Same in the UK. That's why the wiring needs to be able to withstand the fault current.
    I guess here it is mostly contained within a metal tube and unless you play 'fan pants' type games then there is likely to be some isolation from flammable materials.
  • kmikemoo
    0 kmikemoo over 2 years ago in reply to beacon_dave
    Great discussion for a Friday. Relaxed
     beacon_dave Every light fixture that I can remember installing has much smaller wires than the circuit that it gets connected to.  With as small as that wire is, it would probably act as its own fusible link.  If we really think about it, everything we plug into a wall outlet suffers the same risk.  Most power cords are 18AWG or 16AWG.  Even my (now defunct) dehumidifier only had a 14AWG cord.
     Jan Cumps It is the same in the US.  Even the high voltage lighting (277v or 480v) never contains an internal fuse.
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to kmikemoo
    It likely depends on the nature of the fault. If it's dead short then most likely. But what if the fault draws a current that isn't enough to trip the fuse/breaker at the consumer unit but still enough to cause the smaller conductors to go red hot and start melting their way through the insulation. If that isn't contained, e.g. flex across carpet, wood floor, soft goods etc. then you end up with a fire starter situation.
    Here in the UK the plug that is inserted into the wall outlet has its own fuse which usually is rated a such that it protects the flex to the appliance it is supplying.
    I think Big Clive did some flex fire starter cable scenarios on his YouTube channel.
  • Andrew J
    0 Andrew J over 2 years ago in reply to kmikemoo
    I don't ever recall installing a mains-supplied device that had wire that thin though.  Yes, perhaps 18AWG, maybe even 22AWG.  But the gauges you mention can all carry a good amount of current.  I'd made an assumption that the 12W in the letter codes printed on the PCB actually referred to 12 watts, and thus a current consumption of around 50mA but I don't care, the wires shouldn't be that thin for a mains connection.  I don't know if there's likely to be an issue with inrush current or not.
    In this case, nothing is connected up at all, so the purchaser/installer would need to go to town with ferrules and connector blocks and earthing.  It's not right, and I bet the regs have something to say about that for a domestic appliance/fitting. the fact that there's been no attempt at regulatory conformance makes me concerned enough not to use this thing.
  • beacon_dave
    This is not the video I was thinking of but seeing as it is Friday and well, it's Big Clive...
    Cable test ends in flames:
    https://www.youtube.com/watch?v=gwwiCftM4Qg
    All the usual questions included...
    "is it going to burst into flames ?"
    "Should I have a fire extinguisher handy for this ?"
    "I'm regretting doing this on the bench..."
    As an experiment, It's worth cutting some recent IEC power cables.
    When I get a device that comes with a set of IEC cables for several regions, I usually cut one of those that's not for my area. There is regularly not a lot of wire in there. And the wire isn't always copper or copperish anymore.
    But they look and feel thick and strong from the outside.
  • beacon_dave
    If you get a UK 13A plug from a 'questionable source', then its always worth cracking open the supplied ceramic fuse as loads are counterfeit. Amongst other things, there should be quartz sand inside them, which the counterfeits usually don't bother with.
