Ask an Expert Forum TENMA power supply 72-13360: not able to set the target voltage accurately
  • Answers 2 answers
  • Subscribers 335 subscribers
  • Views 1900 views
See a helpful answer?
JeremieWerner
JeremieWerner over 2 years ago
the power supply seems unable to set the correct voltage. anyone had that issue before?
  • saadtiwana_int
    saadtiwana_int over 2 years ago +2
    I have a similar TENMA model at home (I can't remember the model number right now) and it has similar issues. Sometimes the actual voltage can be off by a volt or so (mine goes up to 60V, 1.6A). I tried…
  • JeremieWerner
    JeremieWerner over 2 years ago +2 suggested
    in case someone has this issue, after discussion with vendor, we got a calibration procedure (here attached). but still not helping for the precision. we ended up buying another power supply in similar…
  • saadtiwana_int
    saadtiwana_int over 2 years ago in reply to JeremieWerner +1 suggested
    Ok, I found back my model number. It's Tenma 72-8340A. Please have a look at the following link: https://www.eevblog.com/forum/repair/tenma-72-8340a-calibration-procedure/ There is a pdf attached to the…
  • saadtiwana_int
    0 saadtiwana_int over 2 years ago
    I have a similar TENMA model at home (I can't remember the model number right now) and it has similar issues. Sometimes the actual voltage can be off by a volt or so (mine goes up to 60V, 1.6A). I tried calibrating but after calibrating for few times it got worse. So I just use it as an inaccurate power supply...not for anything fine.
  • JeremieWerner
    0 JeremieWerner over 2 years ago in reply to saadtiwana_int
    Thanks for sharing this experience. how do you calibrate it? I can't find anything in the user manual.
  • saadtiwana_int
    0 saadtiwana_int over 2 years ago in reply to JeremieWerner
    There is a pdf attached to the last post. You can try the same procedure for your supply....maybe the firmware is similar. Let me know how it goes!
    Best Regards,
    Saad
  • JeremieWerner
    thanks. the procedure doesn't seem to work. I can't get into the calibration mode. thanks for the help. I'll try to get it shipped back...
  • JeremieWerner
    in case someone has this issue, after discussion with vendor, we got a calibration procedure (here attached). but still not helping for the precision. we ended up buying another power supply in similar price range: MP711057 DC POWER SUPPLY. It works well and sets the correct voltage!
    0 Jan Cumps over 2 years ago in reply to JeremieWerner
    That is an interesting one. I hadn't seen that before.
    SCPI. Isolated by default, so you'd be able to put some in series if you 'd  need a higher DC voltage...
    10 mV resolution, granular enough for a power supply.
