Ask an Expert Forum Question electronics
  • Replies 35 replies
  • Subscribers 332 subscribers
  • Views 3520 views
See a helpful answer?
cloudff7
cloudff7 over 1 year ago
Why do some electronic devices that were working stop working if they remain unpowered for long periods? Is there an explanation for this and is it possible to avoid it?
  • colporteur
    colporteur over 1 year ago +3
    Components especially electrolytic capacitors dry out. It not from use but age. I have a set of hips that have the same problem:)
  • colporteur
    colporteur over 1 year ago in reply to anniel747 +2
    Quality parts improve the longevity of equipment. Design and manufacturing also play a part. On a recent trip to the Panama canal, the tour guide operator was providing a comparison commentary between…
  • colporteur
    Sorry about that:) I'm retired and the missus has gone to work so I have some downtime to read and write. I enjoy hanging out with the people here. 40 years that expanded five different careers in…
  • cloudff7
    cloudff7 over 1 year ago in reply to anniel747
    all electronics many fragile in storage
  • dang74
    dang74 over 1 year ago in reply to anniel747
    Agreed with bad caps.  I have a C64 with a bad synch pulse and no sound.... I have not opened it up yet.... but bad electrolytic capacitors are my number one suspect all the same.... you will have to elaborate on the 'yellow glue of death' though.
  • anniel747
    anniel747 over 1 year ago in reply to dang74
    [deleted]
  • anniel747
    [deleted]
  • dang74
    Thanks for sharing the article.  Very informative.
  • electronicbiker
    electronicbiker over 1 year ago
    IMHO anything to do with microsoft* is guaranteed to either not work at all or not work after a few days, and if the item is a PC (IBM-compatible or not) it will scramble the OS on what was originally a working PC. I have direct experience of this; my main PC (the one that I am using now) will no longer work with my slide scanner, so I have to keep an old netbook with windoze seven on it in order to retain the slide scanner driver function. The antics of bill gates must have cost world-wide industry trillions over the years purely by forcing office computer managers to upgrade their departmental computers and then forcing them to install further upgrades to correct the numerous bugs in the original upgrade. I have also experienced 'housekeeping', a little-known feature of early microsoft OS's whereby if there wasn't enough memory space on board (including hard drives) the computer would just stop - no warnings, no alarms, no 'STOP' commands to prevent loss of data, no nothing. Meanwhile, incoming data would be lost forever.
    * - The use of unexpected lower-case letters in parts of the contribution above is deliberate; my method of implying that those words do not deserve capitals.
  • cloudff7
    cloudff7 over 1 year ago in reply to electronicbiker
    Any tips for preserving and storing these electronic devices without needing to constantly change the silica gel in each device's box and without a vacuum?
  • kmikemoo
    kmikemoo over 1 year ago in reply to anniel747
     anniel747 I learned of this glue issue a few years back and was completely shocked.  It is real.  I have not seen fires, but shorts... yes.  My experience was in amateur radios - specifically Kenwoods, but I'm sure that it effects others.  Clean it out and the radio is healed.
    "Clean it out" is NOT an easy or fast process. Laughing
  • kmikemoo
    kmikemoo over 1 year ago in reply to cloudff7
    cloudff7 Please forgive me for making this like a Reddit post, but unless you want to preserve the electronics for a nostalgic reason, why?
    Yes, the question is rhetorical.
    I ask because so many of the components become "No Longer Available".
    This isn't always a bad thing as components get better and better.  There are folks that actually stuff new capacitors into old capacitor shells to preserve the appearance.  What is the goal?  (Again, rhetorical)
    I only ask because anything made by man will break.  You can tell I'm in the repair business. Laughing  Is your time and money better spent in integrating the newer technology?  Again, nostalgia changes the equation - but you fight Father Time and obsolescence.  I have seen hospitals have to replace 100kW generators because their starter failed.  (Yes.  There's more to the story, but it's long.  No, there have been no replacement starters for a decade.)
    Again, I apologize for not answering the actual question, but you can't stop entropy.  You might delay it, but you cannot stop it.  This is why Engineers exist.
  • colporteur
    colporteur over 1 year ago in reply to kmikemoo
    The elixir of ever lasting life, grandchildren. Looking after them for an eight hour day requires sixteen hours of sleep afterwards.
    Put them in the box with Schroeder's cat warranties them for a lifetime.
