Ask an Expert Forum Question electronics
  • Replies 35 replies
  • Subscribers 332 subscribers
  • Views 3543 views
See a helpful answer?
cloudff7
cloudff7 over 1 year ago
Why do some electronic devices that were working stop working if they remain unpowered for long periods? Is there an explanation for this and is it possible to avoid it?
  • colporteur
    colporteur over 1 year ago +3
    Components especially electrolytic capacitors dry out. It not from use but age. I have a set of hips that have the same problem:)
  • colporteur
    colporteur over 1 year ago in reply to anniel747 +2
    Quality parts improve the longevity of equipment. Design and manufacturing also play a part. On a recent trip to the Panama canal, the tour guide operator was providing a comparison commentary between…
  • colporteur
    Sorry about that:) I'm retired and the missus has gone to work so I have some downtime to read and write. I enjoy hanging out with the people here. 40 years that expanded five different careers in…
  • anniel747
    anniel747 over 1 year ago in reply to kmikemoo
    kmikemoo You are right. Also seen in Icom and Yaesu radios. Hi-Fi is also struck by this, Pioneer, Yamaha. I guess all japanese electronics used it at some point. Easiest way to remove cleanly is to freeze it.
  • anniel747
    kmikemoo
    www.audiosciencereview.com/.../index.php
  • kmikemoo
    kmikemoo over 1 year ago in reply to anniel747
    anniel747 I will try to remember the freezing approach.  My "one million Q-Tips" approach took forever.  I tried an Exactor knife - and had to replace the capacitor that I damaged. Expressionless  Patience is not my strong suit.
  • anniel747
    kmikemoo It also gets quite corrosive with time, your capacitor was probably already damaged.
  • acdc90
    acdc90 over 1 year ago
    Hello i want to twist your question yes most of the repairs i have done for years has been replacing caps, yes this is pushed by the price of the product, AND it is pushed by the modern consumer, anyone under 30 years would rather have the latest and greatest and they want it now, there for it does not to live for 10 years as they will throw it away after 2 or 3 y
    then look at modern junk LCD tv the componients used will be at there upper limits. i try to fit physicaly bigger caps where i can and push them away from Heat.
    when i was learning it was a NO,NO to put diodes across each other to increse current yet you see that quiet a lot these days
    if i want to keep something i think about ventilation and fitting a Gmov across power and at home old basics like earthing the tv aerial
    another comon problem in 80s/90s was the rubber spacer used on the yoke on tube in tv or monitor,
    the rubber would sweat and eat the wire coating and fry the yoke and line stage
    the oldest colour tv i kept working  was a series 1 philps K9 up to 2005  from 1974
    designed for quality and reliabilty not to a price
