Ask an Expert Forum Need help designing a flow sensor for marine application
  • Replies 9 replies
  • Subscribers 335 subscribers
  • Views 985 views
  • flow sensor
  • flow meter
  • transit-time transducer
See a helpful answer?
e14 Contributor 8 months ago
I want to develop a flow sensor for sea water hose flow rate. It will be used to provide information to be able to shut off and on a water pump. I'd say a clamp on style able to be mounted on a short piece of pipes of various diameters. Any engineers would like to help or guide me in the right direction?
AI is helping me but I'm not an engineer. I have found out that I'll need transit-time transducers (non-intrusive) and a flow rate of 5-100 GPM.
The transducers will be mounted in a short piece of Schedule 80PVC (about 3-4" long) and threaded on both sides for easy installation. There is a product that already exists for my needs but it is Propriatary. (Electrosea "ClearVis" sensor). Basically I'm in need to know the flow rate of sea water so when it is lower than, say 13GPM, send a signal to shut off the water pump. In the available Electrosea system it is used for it's operation and depending on the water flow rate it will introduce current so create cholrine in the sea water to prevent biologiacal fouling. Eventually I'll get there, right now just looking to design that sensor.
Any takers?
Mario
    michaelkellett 8 months ago +1
    Unless your time is of zero value you will not be able to develop a flow sensor like an existing product for less cost than just buying one. You might come up with a novel solution to your problem (but…
  • colporteur
    colporteur 8 months ago in reply to e14 Contributor +1
    https://community.element14.com/products/roadtest/rt/roadtests/583/flusso_fls110_mass_flow_sensor_evaluation_kit#pifragment-18971=4&pifragment-18972=7&pifragment-19828=11 As a community we would be remiss…
    0 michaelkellett 8 months ago
    There are lots,
    You will get better answers if you pin down more of the details:
    like the actual range of pipe sizes, what the pipes are made of, do you need automatic control of the pump, how much are you willing to pay ?
    Here is a start:
    https://nelsonjameson.com/keyence-fd-h22f-clamp-on-flow-sensor-hose-model-15-9-gal-min-7774043-191524.html
    0 e14 Contributor 8 months ago in reply to michaelkellett
    Thanks! I'll add more info. I did research off the shelf but prices are out of range for what I need. Hence me wanting to design one from scratch.
    0 dougw 8 months ago
    You can measure flow rate analogous to measuring electrical current by measuring the voltage drop across a resistor. Pressure corresponds to voltage and a restriction corresponds to resistance. Measuring the pressure at each end of a pipe of known "resistance" allows the flow to be calculated. flow = (Pin - Pout) / r.
  • colporteur
    0 colporteur 8 months ago
    I visited the Newark site and did a search on flow sensors and extensive product selection list.
    There was a few data sheets available to give you some insight.
    0 e14 Contributor 8 months ago in reply to dougw
    I did went down this path but the water flow is too much for this solution, 4-75GPM of seawater. Also there would be way to many turns and loops in the system with verious diameter. The resistor solution fits best on a straight pipe and low flow. But thanks for making me learn a bit more about other solutions. Deifately I've seen paddle flow sensors but I want to avoid intrucion and the seawater would eventually degrade moving parts.
    Thank you again for your input.
    0 e14 Contributor 8 months ago in reply to colporteur
    Thank you for your help! I have been searching and found the  Airmar 1 MHz Ultrasonic Flow Transducer 17mm and Airmar offers a board to connect to it to set parameters for more accurate flow metering result. I'm now looking for less expensive options for prototyping but I'm afraid I wont find an off the shelf board to connect to it.
    Thanks!!
    You might come up with a novel solution to your problem (but since you say you are not an engineer and are relying on AI and forum advice this is unlikely).
    I suspect you best chance of success is to find a way to acquire a ready made sensor that is cheap - maybe a second hand one or a scrap one - or maybe one of these:
    uk.farnell.com/.../flow-sensors
  • colporteur
    0 colporteur 8 months ago in reply to e14 Contributor
    As a community we would be remiss if we didn't plug our RoadTest vendors.
    I saw what you suggested but I need to design something from scratch. I have certain requirements, such as non intrusive, and different diameters I need to meet. So for different size pipe/hoses for marine products. I researched a few transducers like PSC1.0M022302H2AD0-B0 from ZHEJIANG JIAKANG ELECTRONICS (chineese) in order to get started protyping. I'll buy a long piece of Schedule 80 PVC and cut it in short pieces to mount two of these tranducers and see how it goes. Thanks for your help.
