Ask an Expert Forum how to measure wire length at warehouse
  • Replies 19 replies
  • Subscribers 310 subscribers
  • Views 3865 views
  • length
  • warehouse
  • to
  • at
  • measure
  • wire
  • how
See a helpful answer?
I am from INDIA working at MNC .....
I have facing some problem of receiving Wire shortages in Roll .. We have receive 100 mtr roll but at time of kitting found 1 or 2 mtr short.  it is not possible to count roll & measure wire .. it is very time consuming
I want  to know how measure wire length at time of incoming receiving .  if there is any device . Pls help
Thanks & Regards
Pravindra Negi
+919997972016
INDIA
    Jan Cumps over 10 years ago +1
    Weight a good roll, write down, and reject any future roll that weights less?
    michaelkellett over 10 years ago in reply to Former Member +1
    Nothing would be quicker (or cheaper) than weighing the wire rolls. If you are buying a lot of wire it's definitely a quality problem and can only be resolved by QA type methods. When I was involved in…
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +1
    The only easy way I can think of that may do the job is Time Domain Reflectometry (TDR), this sends a pulse down the wire and measures the time for it to reflect but I dont think it will work with just…
    You have posted this in two groups which is not a good thing to do.
    The other group you posted in is for discussions of the Eagle pcb cad system so you should not post a general question there.
    With regard to your wire problem:
    This issue is a quality issue with your supplier - if you only buy a small amount of wire just try someone else.
    If you buy a lot then open discussion with the supplier, ask them to demonstrate how they control the amount of wire on each reel and agree a better procedure. Before you speak to them pick 10 reels at random and very carefully measure the amount of wire on each  - be prepared to share the details of the measuring (method and results) with the supplier.
    Ask your supplier for information with each batch which shows that the amount of wire on each real is acceptable.
    If you have the time consider reading up on Quality Systems and SPC (Statistical Process Control).
    michaelkellett over 10 years ago in reply to Jan Cumps
    The problem I see with weighing is that the OP is concerned about 1-2% loss of length which is only a 1% (max) variation in wire diameter so while low weight might be a good pointer to short length his supplier would argue about it (and if totally unscrupulous could leave the reels somewhere damp for  a week or two before shipping !)
    Former Member over 10 years ago in reply to Jan Cumps
    Have any Device for  measure wire length at warehouse  at the time of incoming .  We have receive many roll at time . So not possible to weight each n every roll. It is very time consuming work.
    Please suggest if there is any Device for measure wire length at time of incoming receiving.
    Thanks & Regards,
    Pravindra.Negi
    +91 9997972016
    When I was involved in running  a business in automotive we received millions of parts and we didn't inspect very many of them (only while there was a problem with a supplier which they either fixed or they lost the business). The automotive customers didn't inspect our stuff either - they screwed it straight onto cars and billed us for the total cost of fixing things if it didn't work (then or during warranty period.)
    dougw over 10 years ago
    I agree, weighing is likely the simplest method for this issue. Bur also check your kitting process - if you are cutting many small lengths, a 1% error in measuring could easily account for the "short" error.
    The only easy way I can think of that may do the job is Time Domain Reflectometry (TDR), this sends a pulse down the wire and measures the time for it to reflect but I dont think it will work with just single core wire, it is usually used with COAX / UTP etc
    https://www.youtube.com/watch?v=0xdRE16CbiQ
    https://www.youtube.com/watch?v=JPnKfPzj3E4
    The good thing is it can be very accurate, now it is also more expensive than weighing, would take longer or certainly not quicker
    Either way if your not wanting to check each one as it is too time consuming then how do you propose to sort ot the good from the bad ?
    Peter
  • peterjcs23
    peterjcs23 over 10 years ago
    how do you measure the rolls to know you have a 2m shortage?
    do you also get some rolls with 2m too much?
    Does that not just balance out over time? +/-2m
    mcb1 over 10 years ago in reply to Robert Peter Oakes
    What if you did two rolls together.?
    Obviously you would need a reference roll.
    If the rolls all come from different suppliers, then you'll quickly work out which one is constantly giving you short rolls.
  • Problemchild
    Problemchild over 10 years ago
    As already said you may find that they state 1-2% error also running down to your last few Metres of any given cable is probably a bad idea but if you want to measure a cable's length how about using some form of TDR(Time domain reflectometer)  type circuit
    https://en.wikipedia.org/wiki/Time-domain_reflectometer
    Measure that Length at the point of purchase
