FPGA
FPGA
Forum My Arty S7 board has killed three USB 3.0 ports on my Microsoft Surface Studio 2 computer.
  • Replies 23 replies
  • Subscribers 580 subscribers
  • Views 6179 views
  • 7 Ways to Leave Your Spartan-6
  • usb hub
  • usb
  • digilent
  • microsoft surface studio 2
  • Arty S7 50
  • Spartan_Migration
javagoza
javagoza over 4 years ago
Yesterday while loading a new bitstream to the Arty S7 50 rev. B the board turned off. At first I thought it was the board, I powered it via USB with a power bank and the board worked. So I tried all three USB 3.0 ports on the computer, a Microsoft Surface Studio 2, with a USB mouse and all three ports were dead.
I have no idea what happened as it is something I have been doing without problems for the last two months, I had not added any new connections either. It only occurs to me that there has been a short circuit in a PMOD connector from which I use the two 3V3 ports for logic voltage for the encoders (VCCENC) and the pull-up voltage for the open-drain encoder outputs (VPU). Also yesterday it was 43ºC, 109F, in my city and I don't have air conditioning at home, I don't know if that could have influenced.
I'm not having good luck with the Arty S7 board. First, when it arrived, on the first day the voltage regulator on the board burned out, maybe due to some faulty component. See thread under Arty S7 rev B vs Arty S7 rev E? Somewhat confused.
And now my computer is damaged, at least the computer still has two other USB ports, one USB-C and another USB-A and with an externally powered USB hub I think I'll be able to get by.
It's a bittersweet feeling, on the one hand I'm learning a lot and enjoying the Arty S7 board and on the other I'm suffering I think it's due to a bad design of the board or my computer, I don't understand how loading a firmware can damage a USB controller, something escapes me. Surely there is some explanation of something that I have done wrong, a layer 8 error, but it is beyond me.
The computer was a prize from element14 for the Sensing the World Challenge and for that alone it has great sentimental value to me. I don't know if it's worth trying to fix this problem or the remedy will be worse than the disease.
I wish I had worked with a self-powered external USB hub.
*SOLVED 2023-01-02*
After a firmware update of the Microsoft Surface Studio 2 for windows 11 the USB 3.0 ports have come back to life.
  • javagoza
    javagoza over 3 years ago +6
    Good news, after a firmware update of the Microsoft Surface Studio 2 for Windows 11 the USB 3.0 ports have come back to life. So, I still don't know how I couldn't fix this from the BIOS as someone suggested…
  • Andrew J
    Andrew J over 4 years ago +3
    Bummer - is there a schematic to see if there is on-board protection to prevent that? The USB ports may have their own internal protection and turning off, and unplugging, the computer will reset them…
  • saadtiwana_int
    saadtiwana_int over 4 years ago +3
    Sorry to hear about what happened. One thing to try, if you haven't already. Completely Shut down the laptop and start again and try the USB ports again using your external mouse, perhaps. I have had…
    dougw over 3 years ago in reply to javagoza
    Wow, it is amazing that a firmware upgrade fixed the USB port issue. Maybe that issue was one of the reasons an upgrade was provided.
    michaelkellett over 3 years ago in reply to javagoza
    Really glad to hear that your computer has recovered.
    A bit concerned that the Windows OS/Driver chain is so weak that this kind of fault can occur and needs an OS re-install to fix.
  • flyingbean
    flyingbean over 3 years ago
    I burned one USB port on one of laptops many years ago due to the short circuity from the fault USB port on the prototype board. I found USB port could be very tricky for FPGA debugging tasks sometimes. The most causes of the USB port issues were from PC driver side.
