Industrial Automation
Forum Component needed. J605 - Power transistor
  • Replies 7 replies
  • Subscribers 289 subscribers
  • Views 4226 views
  • smd
  • power_transistors
nmdk
nmdk over 9 years ago
hi
I am repairing a US made printer. found a power transistor fault. The part no. printed on the component is J605/56L.
But I am not able to find this part on internet. Any one have any suggestion for this replacement? may be a equivalent one?
Any details will help me to solve the issue.
Thank you. I have attached the image of this part. there is two of them on the board.
regards
Nathan
  • tuscaloser
    0 tuscaloser over 3 years ago
    https://www.digikey.com/en/products/detail/infineon-technologies/SPP80P06PHXKSA1/2081673 Hey Nathan, I know this thread is ancient. Looking at the image you attached, I service the same printers for a number of financial/government customers. The link above 100% works as a replacement (it works for the laminator board too). I have fixed maybe 20 main boards so far and none of them have come back yet.
  • guzgus
    0 guzgus over 8 years ago
    Hi Nathan
    To ask you if you did solve the problem with IRF4905PbF equivalent transistor
    reggards
  • nmdk
    0 nmdk over 9 years ago in reply to shabaz
    hi shabaz,
    This is the one I found on the net and easily available, also it comes close to the original one i was looking for. I will give it a try.
    Just to mention, the circuit board is used in a Plastic card printer.
    Thank you for your time.
    regards
    Nathan
    0 shabaz over 9 years ago in reply to nmdk
    Hi Nathan,
    I only briefly checked, but it could be a reasonable one to try. VGS is a little high compared to the original, so if you can find an alternative then that could be better, but without knowing the rest of the circuit I can't say for sure if it will function in the circuit. It depends on the gate voltage (which could be measured but possibly not easily depending on what the circuit is doing and what tools you have). In summary, worth a try, if this replacement is more easily sourced than the original.
  • nmdk
    Hi
    unfortunately I am not able to find exact component.
    This one I am looking for http://pdf1.alldatasheet.com/datasheet-pdf/view/112695/NEC/2SJ605.html
    2SJ605 pdf, 2SJ605 description, 2SJ605 datasheets, 2SJ605 view ::: ALLDATASHEET :::
    I found this once similar to the one I am looking for. Any experts tell me about I can use this one instead?
    http://www.farnell.com/datasheets/2043028.pdf?_ga=2.112629124.1494560299.1505712238-527649267.1505478102&_gac=1.21143081…
  • nmdk
    Yes. it makes sense, Thank you for pointing me in correct direction.
    Hi Nathan,
    You're assuming it is a US component, but it isn't. If you prepend '2S' to the part code, you'll get 2SJ605, which will help you hopefully find a supplier, or the datasheet or enough information about the part, so you can find an alternative that meets your needs.
