Industrial Automation
Forum Wixey circuit board
  • Subscribers 289 subscribers
  • Views 1781 views
Wixey circuit board
rkugler
rkugler over 8 years ago
Does anyone know what the circuit board looking device on a Wixey Saw Fence Digital Readout is called? How does it work?
Roger
    0 genebren over 8 years ago in reply to rkugler
    Not there are anything wrong with rabbit holes every now and againimage
  • rkugler
    0 rkugler over 8 years ago in reply to genebren
    Thanks again Gene, you've saved me from another rabbit hole!
    Roger,
    While technically possible, I am not sure that you could beat the current pricing of $81.00. (see below)
    https://www.tigersupplies.com/Products/Wixey-WR700-Saw-Fence-Digital-Readout__WIXWR700.aspx?invsrc=adwords_ts&gclid=Cj0K…
    The linear scale and optical encoders could easily exceed the $81.00 price.  And you would still need a LCD, switches, microcontroller and a case, not to mention all the necessary mounting brackets and such.  I do not know of any available code for such a module, meaning you would need to do it yourself.  A lot of work, with questionable accuracy and functionality.
    Gene
  • rkugler
    Thanks Gene. Do you know if it is possible to build something like this? Parts? Code?
    Roger,
    It is a digital position readout.  There is an encoder strip that is attached to the saw, and this device can read the encoded position and create a reading that tells the position of the fence.
    Here is a link to their manual:
    http://www.wixey.com/fence/owners/images/wr700.pdf
    Gene
