Internet of Things
Internet of Things
Blog WeatherBrella - Experiencing Brellazilla
  • Author Author: zengirl2
  • Date Created: 12 May 2014 12:49 AM Date Created
  • Views 2900 views
  • Comments 24 comments
  • internet_of_things
  • weather
  • umbrella
  • sparkcore
  • iot
zengirl2
zengirl2
12 May 2014
You may recall that in my last post I described the umbrella business as being rather nasty -- I now have additional support for that theory. The umbrella on the right is the one I received from a company geared to weddings. Their site said returns were impossible and they even declared that they take photos of everything that leaves their warehouse. Well, I guess this little Brellazilla slipped through the cracks. As you can see, the handle is stained, and be glad this is not smellavision. It reeks of cigarette smoke and I can already picture the rainy wedding where this umbrella sat sadly in someone's ashtray. Luckily, once confronted with my photograph, the company immediately decided to take the umbrella back. However, I wasn't willing to risk another purchase with them. I went straight to a company that specializes in umbrellas, and luckily, they carried the same exact brand. I can't tell you how beautiful white looks when it is actually clean and smells fresh (yeah, we all know it is really called off-gassing). Anyway, I'm really excited, not so much by the clean umbrella, but by the screw in its handle.
I wanted a screw in the handle so that it would be removable, making it easier to create a new 3D printed version. Well, the screw on this handle turned out to be misleading. Once I removed it, the handle would not budge. "Oh, it's probably just an awesome pressure fit", I thought to myself. Well, it was a little more than that. Apparently, something was blocking one of the side walls. I tried jabbing with various jeweler's tools inside the bottom of the handle, and it was evident that there was some movement, but not enough to release it. I started thinking of how plastics work, and my first thought was that freezing it might help. So, with my husband's help, we put some canned air inside. It did indeed fog up the metal shaft, but still the piece wouldn't budge. Finally, I thought of how I loosen all syrup jar lids -- a hot faucet. In about two minutes, my husband had a tug of war with the handle, and believe me, he is a stocky 6'3", and the umbrella was no match. Finally, an umbrella without a handle! It turns out, when the screw had passed through, it had caused the metal shaft to dimple, and it was just enough to keep it stuck. I'm just glad it worked, because I wasn't sure if I was just going to have to melt it off.
So, now I can start to imagine how a circuit might work in this small space. I know the SparkCore will be tiny, but I'm still not sure I can fit a battery with it. If I do get the parts to fit inside, I will have to do a screw cap, much like I did with my previous umbrella project, to allow for access to the battery. It may also make the LED situation tricky. I was hoping to use one NeoPixel to conserve energy. However, for a nice glow it would have to be situated at the top of the handle, probably in the way of the screw cap. A better choice would be to use a small NeoPixel strip in a length of 5 or 6 and wrap it around the inside. Not only would it have a nice glow, but it would also be out of the way of the moving parts. There is one last challenge, and that is the button. If I enlarge the diameter of the handle, I will also have to increase the thickness of the button in order for the umbrella to open. So many tricky details to worry about it, but I still believe something interesting is possible. For now, I'm eagerly awaiting the SparkCore so I can get started on the challenge of coding.
    DAB over 12 years ago +1
    Hi Leslie, You are so good at explaining the "unforeseen" elements of making. Take the handle off an umbrella, how hard could it be! Luckily you have the right level of persistence to go beyond initial…
    shabaz over 12 years ago in reply to zengirl2 +1
    Hi Leslie, Thanks! : ) The diagram below shows how the Olimex module can be used: I did a similar circuit topology, to make myself a portable 5V/3.3V power supply (basically just replaced the "Sparkcore…
    Hi Leslie, I cut out an opening, this is what is looked like end-on: This was the completed thing, I had 0V/5V/3.3V wires, that I could plug into any circuit. With the switch turned on, Ithe power would…
  • Workshopshed
    Workshopshed over 12 years ago
    A stack of coin cells?
    You could make the hand grip longer and reproduce the part that mates with the shaft of the umbrella handle.
    You'll be surprised how much you can get inside different things.
    When I was a lad I mananged to get a whole AM radio inside a large pritt stick, the dial at the bottom which usually makes the glue rise up was the tuner.
    I also made a flashing terminator eye with a coin cell and a flashing 5m LED and a prosthetic eye from a joke shop.
  • zengirl2
    zengirl2 over 12 years ago in reply to Workshopshed
    Andy, so far I am liking the idea of extending the length more than the width of the umbrella handle.  On my last umbrella I thought the thicker handle was harder to grasp (although perhaps it would be fine for a man). I think I have to worry about the battery situation because I believe the voltage is being converted through SparkCore's battery shield. So, I think I'm going to need some sort of gadget on there. I love your example of the glue stick -- it's so 007! You know the field of wearables would be loving your abilities right now.
    DAB over 12 years ago in reply to mcb1
    Ah, but I just saw a post last week where someone built an automated coil winder. image
    So winding the coil could be an easy task.
    mcb1 over 12 years ago in reply to DAB
    Sorry the twirling I was referring to was twirling the umbrella past the magnet (on your head) to generate the energy needed to power/charge the battery..image
    I am not sure how you would wind a coil that charges when twirled? image
    Moving a magnet perpendicular to the coil generates the induced current, which I guess could be done, but I just can't visualize it.
    okay ...some design work is needed...image
    Hey I'm just the big idea guy ...
    In the ideal world, the umbrella shaft would be sized to suit batteries.
    A 'bespoke' (as the english say) umbrella would be the ultimate creation for Leslie ...anyone know someone who can make one.?
  • zengirl2
    zengirl2 over 12 years ago in reply to DAB
    DAB,
    I know this is actually a brilliant conversation, but I just keep finding it really funny. I'm picturing doing odd movements while walking with an umbrella -- much like the Ministry of Silly Walks or something.  I would love to see all of you create this crazy energy harvesting umbrella!  I'm picturing a Tesla coil style umbrella with light bolts dancing around.
  • zengirl2
    DAB,
    DAB over 12 years ago in reply to zengirl2
    Actually, you just gave me another idea.
    You could put a couple of the movement based flashlights on your ankles and then run wires up to your umbrella to power the lights.
    The faster you walk, the brighter the lights.
    You could start a whole new exercise craze with competitions to see who has the best walking technique to power the umbrella.
