Internet of Things
Internet of Things
Forum udev rules error on BBB
  • Replies 13 replies
  • Subscribers 522 subscribers
  • Views 2576 views
ramanc51
ramanc51 over 10 years ago
Hi all
             In my BBB i written udev rule 99-usb-serial.rules at /etc/udev/rules.d to fix my usb-serial converter ttyUSB0 name as static(e.g printer), but this rules not create symlink as i given below, alos i saw error that unable to open '/sys/udev/ttyUSB0', is there glue to resolve this error?
my 99-usb-serial.rules
SUBSYSTEMS=="usb-serial", MODE="0666", ATTR{idVendor}=="0403", ATTR{idProduct}=="6001", SYMLINK+="printer"
Error
parse_file: reading '/etc/udev/rules.d/99-usb-serial.rules' as rules file
udev_rules_new: rules use 197880 bytes tokens (16490 * 12 bytes), 32369 bytes buffer
udev_rules_new: temporary index used 60680 bytes (3034 * 20 bytes)
unable to open device '/sys/dev/ttyUSB0'
debian@beaglebone:~$
Note:
        But i am able to open this device as /dev/ttyUSB0 only by my another java application on same BBB, but not as a printer
  • bwelsby
    bwelsby over 10 years ago in reply to ramanc51 +1
    Do you get the error running udevadm test /dev/ttyUSB0 ? Try udevadm test /sys/dev/char/188:0 Are you sure SUBSYSTEMS=="usb-serial" Usually they are "tty" You can also check /var/log/syslog for errors…
  • ramanc51
    ramanc51 over 10 years ago in reply to bwelsby
    Thanks Brain, i solved it by adding symlink names with column separated as follows
       System.setProperty("gnu.io.rxtx.SerialPorts", "/dev/Printer:/dev/Display");
    but i think we can solve it as follows also by script
    java -Dgnu.io.rxtx.SerialPorts=/dev/printer:/dev/dispaly
  • bwelsby
    Great,  Yes and I have just found this too in the FAQ - Rxtx
    You can specify the available ports by
     System.setProperty("gnu.io.rxtx.SerialPorts", portFileNames);
    where the file names of the ports are separated by File.pathSeparator.
  • ramanc51
    Brain, now i am facing another issue that, when job get done by my java app, the device is get disconnected and then appeared with new portname e.g ttyUSB1/2 automatically in /dev directory, now  i send command to that device, job is not get done because port is changed my app assign this device with same symlink that correscopnds to another ttyUSB1/2 on startup, if i restart my app then works once then same issue comes, i don't know why this behavior on BBB, my job is to print token using small thermal printer, this thermal printer is interfaced with BBB through USB-Serial converter(Prolific-PL2303), Do you have any idea or clue about this issue?
