Internet of Things
Internet of Things
Forum udev rules error on BBB
  • Replies 13 replies
  • Subscribers 522 subscribers
  • Views 2574 views
ramanc51
ramanc51 over 10 years ago
Hi all
             In my BBB i written udev rule 99-usb-serial.rules at /etc/udev/rules.d to fix my usb-serial converter ttyUSB0 name as static(e.g printer), but this rules not create symlink as i given below, alos i saw error that unable to open '/sys/udev/ttyUSB0', is there glue to resolve this error?
my 99-usb-serial.rules
SUBSYSTEMS=="usb-serial", MODE="0666", ATTR{idVendor}=="0403", ATTR{idProduct}=="6001", SYMLINK+="printer"
Error
parse_file: reading '/etc/udev/rules.d/99-usb-serial.rules' as rules file
udev_rules_new: rules use 197880 bytes tokens (16490 * 12 bytes), 32369 bytes buffer
udev_rules_new: temporary index used 60680 bytes (3034 * 20 bytes)
unable to open device '/sys/dev/ttyUSB0'
debian@beaglebone:~$
Note:
        But i am able to open this device as /dev/ttyUSB0 only by my another java application on same BBB, but not as a printer
  • bwelsby
    bwelsby over 10 years ago in reply to ramanc51 +1
    Do you get the error running udevadm test /dev/ttyUSB0 ? Try udevadm test /sys/dev/char/188:0 Are you sure SUBSYSTEMS=="usb-serial" Usually they are "tty" You can also check /var/log/syslog for errors…
  • mconners
    mconners over 10 years ago
    Did you come up with that by yourself? Or did you have guidance from another source? i.e. did the device vendor provide you with that example and you just added the symlink on the end?
    Mike
  • bwelsby
    perform a
    udevadm info /dev/ttyUSB0
    to check your values in your rule are correct.
  • ramanc51
    ramanc51 over 10 years ago in reply to mconners
    Mike, VID&PID is belongs to my device, by the guidance on other sites that are referenced i came up, for command ls -l /dev/ttyUSB0 i found the device info is stored in /sys/dev/char/188.0, the result for above command is given bellow, are you telling my udev rules is not correct?
    crwxrwxrwx 1 root dialout 188,  0  Feb 19 22:39 /dev/ttyUSB0
  • ramanc51
    ramanc51 over 10 years ago in reply to bwelsby
    Hi Brian thanks, i checked my rule values with devadm info returns all are correct, i don't know why it is showing error unable to open device on '/sys/dev/ttyUSB0'
  • bwelsby
    You can also check /var/log/syslog for errors that may be a clue.
  • ramanc51
    I found my device SUBSYSTEM = "usb" , now it creates symlink at /etc/dev as expected, but my app is not able to open the device using symlink name
    For e.g i used to open printer comport  as follows
    /dev/printer   -  //dev/printer -> /dev/ttyUSB0
    /dev/display  - //dev/display -> /dev/ttyUSB1
    it says no such port, please share  how to use symlink name to open/close ports
  • bwelsby
    ok so if you
    ls -l /dev/printer
    you get something like
    lrwxrwxrwx 1 root root 7 Feb 20 09:19 /dev/printer -> ttyUSB0
    you should be able to just use /dev/printer in just the same way you would use /dev/ttyUSB0
    If you have something like minicom installed then
    minicom -D /dev/printer
    should open a terminal session with the port
    please can you post the output for
  • ramanc51
    [root@hextek rules.d]# udevadm info -a -n /dev/ttyUSB0
    Udevadm info starts with the device specified by the devpath and then
    walks up the chain of parent devices. It prints for every device
    found, all possible attributes in the udev rules key format.
    A rule to match, can be composed by the attributes of the device
    and the attributes from one single parent device.
      looking at device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5.2/1-1.5.2:1.0/ttyUSB0/tty/ttyUSB0':
        KERNEL=="ttyUSB0"
        SUBSYSTEM=="tty"
        DRIVER==""
      looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5.2/1-1.5.2:1.0/ttyUSB0':
        KERNELS=="ttyUSB0"
        DRIVERS=="pl2303"
        ATTRS{port_number}=="0"
      looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5.2/1-1.5.2:1.0':
        KERNELS=="1-1.5.2:1.0"
        SUBSYSTEMS=="usb"
        DRIVERS=="pl2303"
        ATTRS{bInterfaceClass}=="ff"
        ATTRS{bInterfaceSubClass}=="00"
        ATTRS{bInterfaceProtocol}=="00"
        ATTRS{bNumEndpoints}=="03"
        ATTRS{supports_autosuspend}=="1"
        ATTRS{bAlternateSetting}==" 0"
        ATTRS{bInterfaceNumber}=="00"
      looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5.2':
        KERNELS=="1-1.5.2"
        SUBSYSTEMS=="usb"
        DRIVERS=="usb"
        ATTRS{bDeviceSubClass}=="00"
        ATTRS{bDeviceProtocol}=="00"
        ATTRS{devpath}=="1.5.2"
        ATTRS{idVendor}=="067b"
        ATTRS{speed}=="12"
        ATTRS{bNumInterfaces}==" 1"
        ATTRS{bConfigurationValue}=="1"
        ATTRS{bMaxPacketSize0}=="64"
        ATTRS{busnum}=="1"
        ATTRS{devnum}=="88"
        ATTRS{configuration}==""
        ATTRS{bMaxPower}=="100mA"
        ATTRS{authorized}=="1"
        ATTRS{bmAttributes}=="a0"
        ATTRS{bNumConfigurations}=="1"
        ATTRS{maxchild}=="0"
        ATTRS{bcdDevice}=="0300"
        ATTRS{avoid_reset_quirk}=="0"
        ATTRS{quirks}=="0x0"
        ATTRS{version}==" 1.10"
        ATTRS{urbnum}=="463"
        ATTRS{ltm_capable}=="no"
        ATTRS{manufacturer}=="Prolific Technology Inc."
        ATTRS{removable}=="unknown"
        ATTRS{idProduct}=="2303"
        ATTRS{bDeviceClass}=="00"
        ATTRS{product}=="USB-Serial Controller"
      looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5':
        KERNELS=="1-1.5"
        SUBSYSTEMS=="usb"
        DRIVERS=="usb"
        ATTRS{devpath}=="1.5"
        ATTRS{idVendor}=="058f"
        ATTRS{speed}=="12"
        ATTRS{bMaxPacketSize0}=="8"
        ATTRS{busnum}=="1"
        ATTRS{devnum}=="84"
        ATTRS{bmAttributes}=="e0"
        ATTRS{maxchild}=="4"
        ATTRS{bcdDevice}=="0312"
        ATTRS{quirks}=="0x2"
        ATTRS{urbnum}=="136"
        ATTRS{manufacturer}=="ALCOR"
        ATTRS{removable}=="removable"
        ATTRS{idProduct}=="9254"
        ATTRS{bDeviceClass}=="09"
        ATTRS{product}=="Generic USB Hub"
      looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1':
        KERNELS=="1-1"
        SUBSYSTEMS=="usb"
        DRIVERS=="usb"
        ATTRS{bDeviceProtocol}=="01"
        ATTRS{devpath}=="1"
        ATTRS{idVendor}=="8087"
        ATTRS{speed}=="480"
        ATTRS{busnum}=="1"
        ATTRS{devnum}=="2"
        ATTRS{bMaxPower}=="0mA"
        ATTRS{maxchild}=="6"
        ATTRS{bcdDevice}=="0000"
        ATTRS{version}==" 2.00"
        ATTRS{urbnum}=="1932"
        ATTRS{removable}=="fixed"
        ATTRS{idProduct}=="0020"
      looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1':
        KERNELS=="usb1"
        SUBSYSTEMS=="usb"
        DRIVERS=="usb"
        ATTRS{devpath}=="0"
        ATTRS{idVendor}=="1d6b"
        ATTRS{speed}=="480"
        ATTRS{authorized_default}=="1"
        ATTRS{busnum}=="1"
        ATTRS{devnum}=="1"
        ATTRS{maxchild}=="3"
        ATTRS{bcdDevice}=="0309"
        ATTRS{serial}=="0000:00:1a.0"
        ATTRS{urbnum}=="267"
        ATTRS{manufacturer}=="Linux 3.9.10-100.fc17.i686 ehci_hcd"
        ATTRS{idProduct}=="0002"
        ATTRS{product}=="EHCI Host Controller"
      looking at parent device '/devices/pci0000:00/0000:00:1a.0':
        KERNELS=="0000:00:1a.0"
        SUBSYSTEMS=="pci"
        DRIVERS=="ehci-pci"
        ATTRS{irq}=="16"
        ATTRS{subsystem_vendor}=="0x8086"
        ATTRS{broken_parity_status}=="0"
        ATTRS{class}=="0x0c0320"
        ATTRS{companion}==""
        ATTRS{consistent_dma_mask_bits}=="32"
        ATTRS{dma_mask_bits}=="32"
        ATTRS{local_cpus}=="ffffffff"
        ATTRS{device}=="0x3b3c"
        ATTRS{uframe_periodic_max}=="100"
        ATTRS{enable}=="1"
        ATTRS{msi_bus}==""
        ATTRS{local_cpulist}=="0-31"
        ATTRS{vendor}=="0x8086"
        ATTRS{subsystem_device}=="0x0036"
        ATTRS{d3cold_allowed}=="1"
      looking at parent device '/devices/pci0000:00':
        KERNELS=="pci0000:00"
        SUBSYSTEMS==""
        DRIVERS==""
  • ramanc51
    Now i am able to open port using symlink name on my java app by using following line
           System.setProperty("gnu.io.rxtx.SerialPorts", "/dev/printer");
    But according to rxtx lib source, it will omit other device if we user system property method, so that i can't use more than one device using it's symlink name,
    is there any way to load more than one symlinked devices?
    Reference
    Trouble shooting - Rxtx
    If you wish, you can set the system properties gnu.io.rxtx.SerialPorts and gnu.io.rxtx.ParallelPorts. If either of these is set, then no scanning will be carried out and only the specified ports will be available
  • bwelsby
    Have a look at this it may help, it applies to  both RPi and BBB  http://angryelectron.com/rxtx-on-raspbian/
